how is this different from D-Link red spider / crab router i.e. DIR-890L?
Dear JL,
Speedtest do not reflect real time usage.
What is your link speed for your client?
Best regard,
JK
Hi JK
you caught me there. What is link speed? where do I test this or set this?
My pcs are wirelessly connected on 5G , mobile phones on 2.4Ghz
Regards
JL
On windows machines, link speed is indicated as "Speed". On windows 8/8.1/10 go to "Network and Sharing Center", click on your connection under "view your active connections".Hi JK
Regards
JL
Which plan?Hi everyone, just got the router today and couldn't get it connected to Internet (red globe).
I'm on Singtel fibre, connected the ONT to WAN. Used the quick setup, selected both Singtel MIO and Singtel Others. Both doesn't work. Cannot detect dhcp.
I read from this thread that a few other guys here also have the same problem but I didn't see any solution posted.
Anyone who knows the solution Pls help. Getting very frustrated.
Thanks in advance
Thanks for the reply. I also tried with no special setting and it still doesn't work.
I connect ONT port 1 to WAN on the router, launched the setup wizard and didn't choose special setting.
Still doesn't work.
On Android devices, go to Settings/WiFi click on your connection and should show you the link speed.
On Apple devices, no idea!
Thanks Mario/JK
Speed on connection for wireless adapter says 867.0Mbps.
hi guys...can somebody point out whats wrong with my wifi configuration on RT-AC87U
I've been experiencing slow wifi speed on my iphone 6+...sometimes when i update my apps from apple store the updates will just get stuck and not move. can take up to 15mins and still see no progress...
after i disable wifi, the updates continue normally using 4G...
JK, this version got some issue with the IPTV VID for Internet.Dear all,
RT-AC87U_3.0.0.4_378_7944- Unofficial beta firmware
This firmware does not contain new SDK.
Best regard,
JK
I can't connect to Singtel and the LED stays red color.
Tested last night. ******************
I want to boot a router program, Asus official firmware how to do? I know a friend told me about, thank you!I have removed.
Please remove your quote url.
Best regard,
JK
Dear JK,Dear Shaobing,
What are you talking about???
Best regard,
JK
Dear JK,
My AC87U use USB3.0 interface to connect mobile hard disk. I installed the router inside the Thunder plugins. It can be downloaded offline, and now use a router suddenly restart occurs, does not recognize the removable hard disk and so on. How do you resolve it? Also AC87U the fastest USB3.0 can reach the number it? Tell me about the trouble
Best regard,
Shaobing
