renfred89
how is this different from D-Link red spider / crab router i.e. DIR-890L?
890L is a tri band ac3200 router and ac87u is a dual band ac2600 router. Both are different in terms of MU-MIMO vs broadcom's smart connect.
I think it's better u go read up yourself..
Lunner
Dear JL,
Speedtest do not reflect real time usage.
What is your link speed for your client?
Best regard,
JK
Hi JK
you caught me there. What is link speed? where do I test this or set this?
My pcs are wirelessly connected on 5G , mobile phones on 2.4Ghz
Regards
JL
renfred89
Hi JK
Regards
JL
link rate can be checked from the wireless device itself. different device got different ways of checking, but the option should be somewhere in your wifi settings..
MarioCaires
Hi JK
Regards
JL
On windows machines, link speed is indicated as "Speed". On windows 8/8.1/10 go to "Network and Sharing Center", click on your connection under "view your active connections".
On Android devices, go to Settings/WiFi click on your connection and should show you the link speed.
On Apple devices, no idea!
yenz
Hi everyone, just got the router today and couldn't get it connected to Internet (red globe).
I'm on Singtel fibre, connected the ONT to WAN. Used the quick setup, selected both Singtel MIO and Singtel Others. Both doesn't work. Cannot detect dhcp.
I read from this thread that a few other guys here also have the same problem but I didn't see any solution posted.
Anyone who knows the solution Pls help. Getting very frustrated.
Thanks in advance
thiamhui
Thanks in advance
Which plan?
For Unlimited plan, you don't need the special settings.
yenz
Thanks for the reply. I also tried with no special setting and it still doesn't work.
I connect ONT port 1 to WAN on the router, launched the setup wizard and didn't choose special setting.
Still doesn't work.
renfred89
Still doesn't work.
Kindly state which plan you are using.. :)
For unlimited fibre, have u tried plugging ur computer to ONT, bypassing the router and manage to surf the net?
Lunner
Thanks Mario/JK
Speed on connection for wireless adapter says 867.0Mbps.
MoneyHoney
hi guys...can somebody point out whats wrong with my wifi configuration on RT-AC87U
I've been experiencing slow wifi speed on my iphone 6+...sometimes when i update my apps from apple store the updates will just get stuck and not move. can take up to 15mins and still see no progress...
after i disable wifi, the updates continue normally using 4G...
renfred89
common issue... LOL
does it work better after a reboot? if yes, then its the nature of the wireless router, not anything else..
ASUS@SG
Suspended
Dear all,
RT-AC87U_3.0.0.4_378_7944 <Removed>
Best regard,
JK
thiamhui
Dear all,
RT-AC87U_3.0.0.4_378_7944- Unofficial beta firmware
This firmware does not contain new SDK.
Best regard,
JK
JK, this version got some issue with the IPTV VID for Internet.
I can't connect to Singtel and the LED stays red color.
Tested last night. 😁
ASUS@SG
Suspended
Tested last night. ******************
I have removed.
Please remove your quote url.
Best regard,
JK
shaobing_1010
Dear Shaobing,
What are you talking about???
Best regard,
JK
Dear JK,
My AC87U use USB3.0 interface to connect mobile hard disk. I installed the router inside the Thunder plugins. It can be downloaded offline, and now use a router suddenly restart occurs, does not recognize the removable hard disk and so on. How do you resolve it? Also AC87U the fastest USB3.0 can reach the number it? Tell me about the trouble
Best regard,
Shaobing
ASUS@SG
Suspended
Dear JK,
Best regard,
Shaobing
Dear Shaobing,
Your firmware version:
USB storage model & brand:
Best regard,
JK
