Bad case experience
ahjunz
Was gonna help a friend build a new pic and what a surprise I got when open up the casing cardboard box.:eek::eek:
Define R5 become ReDefined
PS: Cardboard box wasn't dented at all.
iZoneSG
better go back shop and swap one to one ah. What shop u buy from?
ahjunz
From sim lim sq,won't name the shop yet as this could happen to anybody. The thing isn't about 1 to 1. If GPU/Mobo DOA still easy carry by hand. Casing so big n heavy. Need to cab to and fro...hai....
localITguy
Suspended
could be damaged in shipping. might not be shop's fault
Koenig168
If the box is fine, then you can't really blame the shop since the staff might not know.
Good luck getting a refund though. It will not be easy to convince the shop that the manufacturer would ship out a case like that.
localITguy
Suspended
CONTACT DISTRO, I AM sure if cannot 1to 1 distro will handle it
Op_Valkyrie
the QC eyes tia stamp or is really out to spoil the company's reputation... can't be not detected by anyone....
i know lian li case once they QC done they got stick a small QC sticker... hmm for this....
MoneyFace =p
Mystery aside, did Fractal Design begin cutting corner on structure panel thickness? Wasn't their chassis panel thick and heavy like their original series?
jtjt00
Someone/somehere is out to trouble a customer. The case is obvious damaged before being placed into the carton box.
t258jgn
If you stay East side. Maybe nearer to exchange at Convergent Systems
most probably caused by during loading into the container before shipping.
kandinsky
was the styro broken ?
Yeah, this was the first question I had too, when TS mentioned the box wasn't dented at all. The internal styrofoam packaging support is damn thick and quite snug. If it is also intact, then that means the casing was already damaged prior to being placed inside.
royfrosty
When I was handling the R5 a few months back, the metal/steel used is definitely very sturdy and solid. It cant be bend easily.
This is high chance that it was already damaged before packing in. And it require a lot more force to bend it.
High chance if this were auto packed by machines, it could be damaged by machines.
This is the first time I see such things happen.
