Hi guys,
i recently bought ac87u updated to the latest firmware 9177.
i am on fibre 200mbps plan but on 2.4ghz i am getting max
50mbps but on 5ghz i am getting like 170mbps. is there any
setting i miss out in 2.4ghz ?
why ip6 got so hot using 5ghz
Only Note 4 can scan 5Ghz or all devices? Are you able to scan 5GHz of neighbor? Usually the SSID will contain 5G behind.Hi i need help. I use note 4 to connect 5ghz ssid but after few weeks, i unable to scan for 5ghz ssid and now i using 2.4ghz one.
Hi guys,
getting a 1gbps plan and planning to get a better router too.
how much would this ac87u cost?
Dear all,
RT-AC87U_9.0.0.4_378_9110 - Unofficial Beta
Download: http://goo.gl/ud2RKQ
- Require factory reset after update.
Added
1. New wifi driver to improve wifi connection
2. Traffic Analyzer for monitoring your network traffic
3. Bandwidth Limiter in Adaptive QoS
4. USB to USB smart sync mode
5. A scheduler for Router Reboot
6. Can edit offline devices in client list
Update
1. Update OpenSSL to 1.0.2d
2. IPTV ISP profile setting of 'movistar' & ‘meo’
3. Adjust maximum number to 16 for Guest Network MAC filter
4. Web History/Traffic Analyzer can show device name.
5. Allow user paste password on login page
Fixed
1. Media server cannot scan files
2. Cannot complete QIS setting on IE11
3. Download speed is limited by Upload speed in Traditional QoS
4. Unexpected UI display issue
Best regard,
JK
Hi All,
Thought I saw there's a new feature - "scheduler for router reboot" on the earlier firmware 9110.
Think I might have missed it but I couldn't find this feature in both 9110 and the latest 9177 firmware.
Appreciate if someone could enlighten me on where I can locate this feature. Thanks.
Still problem with battery drain on ANDROID by 5GHz.
This is unacceptable in its class. I can not use it because the battery disappears in his eyes. When ASUS will solve this problem soon because I only heard soon
Best regard,
JK
