seowbin
- Oct 10, 2001
what oil u selling? can PM boFeeling can be misleading and not all engine oil are created equally.
” Passenger car motor oil is the lifeblood of your engine. In addition to lubricating moving parts to help reduce wear and tear and the buildup of heat in your engine, motor oils contain performance additives that help to reduce oxidation, neutralize acids, prevent rust, corrosion, and foam, condition seals, save fuel, and keep your engine clean. But all engine oils are far from created equal. In fact, some motor oils on the shelves can cause harm to your engine and premature failure. Know what motor oil goes into your car”.
Quote: PETROLEUM QUALITY INSTITUTE OF AMERICA
SAMPLE SUMMARY /PASSENGER CAR MOTOR OIL
In fact, if you look at the testing below, those unknown/relabel products have the most problem and some will actually do damage to your car engine.
http://www.pqiamerica.com/samplesummaryPCMOrev4test.htm
5w30 for vw
