TV repair discussion thread (consolidated)
Henry Ng
If it was a direct lightning strike extensive damages would be obvious. This scenario is unlikely because all our buildings are protected against direct strike. [Latest building codes also specify protection against lightning surge]
It would be difficult, if not impossible, to proof that the tv failed because of lightning surge. There won't be tell tale sign unless you inform the Service Centre.
Since your set is still under warranty, send it to Bedok. It may be far away unless you live nearby. But I believe they will honour the warranty. In any case they will inform you of the repair cost for your agreement, if charged, before they proceed. That's my experience with Panasonic products. Out of warranty repairs are usually slightly less than half of cost of products.
Yes it would be difficult to tell and may be it is not lightning surge.
AnA
Hi Freakinclown,
My TV is LG42LW5700 bought few years ago and cannot power up, red colour standby light is ON. Please advice how much is the repair? Appreciated your reply and thanks.
Henry Ng
Hi Freakinclown,
Honestly 42" tv now has more new features and it doesn't cost that much. It is around $700+ to $800+. Even bigger size FHD also just a bit more only. 49LF630T is a good example. If u like UHD can consider 43UF640T which is $900+.
AnA
Thanks Henry, Ok, I may consider getting new. Appreciated your advise.
raynerho
My Sony Bravia 32EX600 bought in 2010 has been temp error issues for the past 3 years, starting to get more frequent since I just bought a PS4 and is playing on it.
Basically, after random timing of playing (sometimes an hour, sometimes less), the TV will shut off, with 7 blinking lights. Went into the diagnostic menu and saw it as TEMP_ERROR, and it occured 31 times over the past 3 years. The TV can work again after resting/cooling for a while
Saw Mr Ho's contact 62524555 and wondering if he is able to repair this issue? This TV was pretty high end when I bought it and it suits my needs of 4 HDMI ports, and the similar current model is about 600 plus, pretty pricey as well. If I can repair it, it will be better!
Thanks!
Henry Ng
Thanks!
What you did not get it fixed during its 3 years warranty period? Do you know how expensive it is to repair such Sony Tv? I have given up on Sony Tv. It is either motherboard or switchboard and it cost ~ $180 each. If both are faulty then it will be $360 just for the part. After 6 months the problem may come back again.
raynerho
Made a mistake! Warranty was over when this problem occured. Nevermind, will give Mr Ho a call see if there's anything that can be done! Thanks!
Henry Ng
What to do if spoil again after repair for 3 mths? 5 yrs old Sony Tv the features are quite old. No point repairing it as getting a new 32LF630T is below $499. 2015 model with new features. Do consider carefully.
HeeroYuy84
Where to repair if samsung 48ju6400 panel crack? Appreciate any advice..
Henry Ng
At start up picture has all kinds of wierd colors - see the color of hair and clothes. After a while color becomes normal. Problem just started.
What is the tv size? FHD or HD? If just a 32" tv it is not worth repairing as sometime after repair the problem may come back again after 12 months.
s7460597
42" already >4 years. Preparing mentally to get new one. :(
