Digital TV (DVB T2) Consolidated thread II
sunsetbay
Moderator
Moderator
Yo!
Anyone stay in Tampines?
Can receive Mediacorp Digital TV broadcast channels ?
Thanks.
from tamp, low floor~ can receive using own antenna but hv to extend out of the window to recv all mediacorpse digital channels~ my MATV also can recv but not msia digital channels~ anyway, i dun use dvb-t2, i'm using DVB-C STB instead, more stable~
albertlee
What's the brand/model of your DVB-C STB?
I think the notice is put on today, yesterday there was nothing.
This notice appears on chn 700, 701, 702.
Yup, I also noticed that...
they put on CNA and CH U
whereas other channels don't have from CH 8 to CH5 to malay and indian channels.
hmmm I wonder they will boast their signal
because my side got blind spot...which affect the HD signal.
chengsun
They put on CNA, CHU and OKTO, which is 700, 701, 702. This 3 moving to 006, 007, 008. All these original channels used by them. The other channels not affected so dun have I guess.
I called mediacorp to feedback just now. coz my place:
1. indoor signal strength very bad
2. the 570Mhz channels signal quality very bad even when I put my antenna beside the windows. I did a manual search, the signal quality and strength never goes above 40 (out of 100).
albertlee
coyote
STB with DVB-C tuner is still too expensive, wouldn't been considering buying anytime soon as already got cheap DVB-T2 STB, and T230 USB TV stick which support DVB-C as well.
I have the T230 usb stick. But the software does not allow me to choose between dvb-c or dvb-T2. If connect it to my wall socket, it scanned tonnes of channel encrypted and non encrypted ones. How can I tell which channels are dvb-t2 or dvb-c?
albertlee
SCV point do not carry DVB-T2 signal. As for scanning of non-encrypted (basically FTA) channels, it depend on the software used. Some allow scanning only for FTA and non-encrypted channels, unfortunately TotalMedia is not one of them.
dexter9898
Are you using an active antenna?
chengsun
Haha, Mediacorp tech uncle just called me. He also asked if I am using passive or active antenna. Mine is passive since no USB connection. He is loaning me a Funke antenna to test at my home.
chengsun
Using a loaned Funke antenna now, everything swee swee even when I put it just below my TV, 2, 3 meters away from windows. Can even receive the SD channels.
Henry Ng
Earlier you are having difficulty receiving it. Mediacorp may have enhanced the signal. In general, this funke antenna quite good but not very cheap.
b00mxer
It's definitely the antenna. Before that I was using other antenna reception was weak but after getting the funke, reception improved. ;)
hwaa
hi. just to check if its possible to receive the starhub sports channel using digital antenna? cant seems to tune to that channel.
b00mxer
i bought a digital ready tv also, just bought an indoor antenna but cannot receive the supersports arena free channel from starhub... isit normal?
Supersports arena is currently not being carried on DVB-T2. You might want to petition/feedback over to StarHub/MDA to carry the channel over.
Kiwi8
Deluxe Member
Of course normal lah. SuperSports Arena is only available via either DVB-C or analog when connected to StarHub's TV point. U use indoor antenna how can it be connected to StarHub's TV point? The signals aren't transmitted through the air unlike MediaCorp's DVB-T2 signals. :s22:
