Windowlover
- Sep 13, 2009
Looking forward higher resolution as still lacking for stability and PQ.
It will remain at 1080i for many years. There is no incentive for them to upgrade the bandwidth to do 1080p.MediaCropTV DVB-T2 only at 1080i. Look very blur on Full HD LED TV. Hope they can switch 1080p soon
Is it that bad?
Since the active antenna relies on the antenna amplifier to turn from passive to active, I paired my DIY biquad antenna with the amplifier from my Funke/Margon Home 2.0 for some testing.
With USB power supplied to the amplifier, TBS 5220 showed signal quality/SNR of 100% and Signal Strength of 95%, Channel 8's Sheng Siong Show 18 used for this testing.
When I cut power to the amplifier, there was no change to the 2 figures.
Is it that bad?
I hate it when I bought a lousy and expensive antenna.
Have to adjust the antenna until you find a sweet spot for all the channelsAnyone experience stutters on Ch U at 570MHz ?
Damn annoyed by it while watching shows on Channel U, like watching some pirated DVDs..
Sent from my Rice phone using GAGT
Last time was good only now then start to face it more frequently.Have to adjust the antenna until you find a sweet spot for all the channels
Sent from LGE LG-D855 using GAGT
It used to be good, only recently. I got an active antenna with amplifier switched on plugged to my TV's USB portChecked back my replies in this thread. That happened to me for the past 2 weeks plus., ChnU, CNA HD n Okto HD. Until I get a loaned active antenna to try at home and all are good now. Will buy a set before I return the loaned antenna.
Got my antenna around 12 Jan. Before that was good, only from yesterday onwards started to see this more frequently(previously there's some stutter but very rare)I think mine got bad ard the same period as urs. I only started watching digital on 1st Jan. For the 1st week or so it was good. Only after that the 3 channels got very unstable.
Hmm cool, didn't know there's such hotline hahaYou can call Mediacorp Digital helpline to feedback and see what they can offer. They are quite responsive to my feedback and loan me the active antenna to test.
I'm using Wavecom antenna now, all's good now with an active amplifier attached. Good with its cheap price.Anyone got recommendations for antenna? My TV coming on wednesday.
So far I've only managed to search wavecom at qoo10 and daiyo at departmental stores.
Not sure which one is better.
You can also consider the Margon/Funke antenna too, available at Fairprice Xtra hypermarts too
