A50 and A30
uplorry
Suspended
Bro, can share usage experience for P30 Lite compare to A70? Tks in advance.
To me, the A70 is definitely a better phone, but I feel that the P30 lite should be compared to the A50 as they are around the same price point.
A70
+ Higher performance (especially in games)
+ Great AMOLED display
+ Impressive battery life
+ NFC
+ FM radio
- Obvious plastic build
- Unreliable and slower in-display fingerprint scanner
- Lack of third party accessories (as of now)
P30 lite
+ Solid build quality
+ Cameras perform well in low light
+ Physical fingerprint scanner is fast and reliable
+ Pocketable size (easier one hand use)
+ 2 year warranty
- Lower performance (noticeable stutters in UI)
- No NFC
- Free case did not fit the phone
Both lack wireless charging, but that's not an issue for me as I don't own a wireless charging dock.
shuttlex
Anyone using A70 find that the speaker is really soft?
Anyway to make it louder?
Sent from Samsung SM-A705MN using GAGT
uplorry
Suspended
Those concerned about the sizing, the A70 is about the size of the iPhone 6 plus, but just slightly taller.
TerryPower
ya, A70 is long. now i am considering whether to get A70 or last year's A9
i bought A7 recently
if you don't like the small "hole" on top, then A9 for you. just like i chose A7 instead of A50
if you not bother with the small hole, then get A70. after all, why get something old when you have something new?
Glariel
S8+ is a flagship phone while A70 is not
I would say it’s not worth it.
Pocoyoz
A70 $443 shopee flash sale
can -$20 (posb card and voucher)
cheap anot?:s11:
joesph
A20 also come out. think it has ultra wide lens
Sent from Samsung SM-G975F using GAGT
ferocity
A70 not really big is just look long a normal lady can hold the phone with just one hand
Agree. Eyeing the A70 and managed to play with a demo set at Courts. My current phone is a Oneplus 5t which is 6.01". The 6.7' A70 is only a tiny bit wider while more elongated. Single hand operation is more than possible. Problem i see with the enlongated screen is that the phone might stick out if pants or trousers dont have deep pockets.
