Advice for new machine
mike911
Just to confirm, for plextor ssd's warranty is 3 years by convergent?
mike911
Depends on which model bro.
Plextor m5s 3 years
Plextor m5p 5 years.
oh didnt knew got 5 years for m5p? Okays, that's great to hear.
Means intel vs plextor I only got to decide between more space vs speed.
mike911
Based on Linus Explanation, and reviews elsewhere.
High Speed RAM - Is it Worth it? DDR3 1333MHz vs 2400MHz Test - YouTube
For KVRs @ 1333Mhz CL9 vs HyperX Blu 1600Mhz CL9. I believe we will only see some minor benchmark numbers differences.
However from kingston's spec sheet, it would appear that higher frequency rams seems to consume more power? Although they performs and are priced similarly (+/- $4), would it still be a better overall to go for Hyperx or for the KVR?
royfrosty
For aesthetic purposes then hyperx will look more nicer. lol
mike911
true, but the brown mama board along with the colorful psu connectors will be like, with the 280x :s22:
So in total will have brown, blue, black, red, green? :s13:
Oh btw, the hyperx in the pricelists are hyperx blu right? Red and Black are higher grades correct?
royfrosty
Haha. Multi color rig.
Yeah. They have green & blue.
mike911
Just checked that Fractal Design Arc Mini R2 can only support up to 292mm GPUs, with HDD Cage on on default orientation. With the cage rotated only up to 260mm supported
Edit : Correction on supported length.
royfrosty
shadow84
Why not just remove it??? Unless u using 8 hdd/ssds... And i think after u rotate it and remove the trays, should be slightly longer than 292mm?
mike911
On 1440 then no ba. If off AA still can get around 40+fps at minimum
But on Xfire im sure it can haha.
I should not have issues turning off AA.
If i recall correctly, below 25-30fps is not playable?
The next gpu to look at is 290 I presume? Although will need to wait for aftermarket cooler.
Dont think I will be looking at x-fire/sli.
Now I'm looking at 1 ssd only. (will need 2 bays for 3.5" for disk transfers time to time)
On default setup, it can support more than 260mm
If it is rotated to the better air-flow position it will only support max 260mm GPUs.
royfrosty
Yes 290. 30fps is quite slow. But games like Crysis 3 very hard to even drive 60fps ><
mike911
1 or 2 games that are super gpu intensive, I'll just let it go. As long most of the other casual games can 走车顺顺 ok liao. :s13:
290 estimated pricing is about $100 sgd more?
royfrosty
$150 more around there if you want custom card.
mike911
Wow okays will consider. Or maybe I'll run scaled 1080p on 1440p panel.
Btw bro, any fans to recommend?
E.g. Corsair AP/SP, noctua, or the infamous gentle typhoon?
royfrosty
AF is meant for chassis fan.
SP meant for Radiator
For gentle typhoon it is good for Rad. But quieter than SP series. 1850rpm vs 2200rpm sure the SP can be heard.
Never try Noctua so not really sure.
