Advice on gaming rig
lifeishard
i did ask whether did is easy to take out mobo and gpu then fix it by myself.
but i not very confidence, scare i mess up and make spoil.
Nvm la, pay $15 guaranteed madcow promised problem will be gone and assembly is done by them quite ok.
ragnarok95
Senior Moderator
Senior Moderator
If you have no confident then just pay S$15 ask them fix up for you.
MianBaoFren
i understand. first time do is very scared one. but actually once u try before, u realise it's very very easy. and i advocate people to try themselves when they diy so they have more confidence when it comes to troubleshooting in the future.
but if u want to get others to do it for it, i won't insist la. your choice.
iNoStandard
yupyup .
thanks for all the trouble and help .
cheers :s12::s12:
kurui_
You can watch some videos than try the process of fixing with your old mobo and CPU if you're afraid you screw up.
More confident already than fix your new ones. It's quite simple actually, imo.
-Synchronicity-
Putting everything together isn't difficult. Treat it like lego. Cable management on the other hand.....
EatSnakeWarrior
the feeling of kena chop , demoralise . :(
i have yet to make a 100% comfirm plus chop getting 1070.
still thinking whether should i go lower because if i were to just play dota 2 , 1070 like high end.
last time my 560ti only like 200+ and play smoothly :s8:
Dont need 1070 la, your monitor wont be able to enjoy the frame rates as its 60hz
Just save $ and get the zotac 1060 3Gb at 240(300-2%-50-4 from gift cards)
The Zotac will be able to smoothly run all your current games
Sent from Sony E6853 using GAGT
