Air Flow in PC CPU
ZawLee
Idle or game mode?
I intend to remake my room next year since everything in my room had rotten to rust and dust - -
killerslayer92
r9 270 devil edition powercolor.
I am planning to buy gtx760 msi twin frozr liao. r9 270x is only good for air con or cooling system casing. hahaha
devil edition is a OC card. might be bcos of that.
gtx760 reference card from palit hit 70-80deg during gaming fyi
twin frozr probably lower
ZawLee
at least this gtx 760 twin frozr is better than 560 ti sonic in temp. I last saw 560 ti sonic temp 78 before it went for RMA.
DeenzX
Eh, wah. But 82C is seriously hot man. My GTX580, reference card, only reaches 72-75C MAX during dota. I mean reference cards are normally hotter, but yours took the spot man.. I think 1 intake and 1 output definitely not enough for you.. Should spend maybe around 80 bucks on a better casing.
ZawLee
Isn't bd28 the norm? It was recommended by veterans hwz users here. I have an idea on how to address my airfow bd28. I definitely need a liquid cooler but I am not sure it will void my powercolor r9 270x devil card or not.
The bd28 is definitely good for airflow optimization. Btm casing can intake x2 120mm fan next to psu. My only problem is whether to use static pressure to force airflow in to the gpu area or use high performance fans.
I agree all exhaust fans should set as low performance. I dislike how they take out more positive pressure than negative
naked123
your card is actually supposed to be cooler than mine.
the problem is your case not having enough cool air blowing in it.
ZawLee
There's no cool air in my room.. coz next to sibeh hot carpark even at night. All the exhaust airs keep come to my windows. That's why I bo pian.
I need to re position my computer table le.
Idle mode is okay though, temp 40 degree.
DeenzX
If the environment is already warm, I wonder if liquid cooling will make a different because the fans would be blowing warm air through the radiator anyway.
Maybe if you can get alot of SP fans, you can attain cool air.
Go watch this video:
Ultimate Corsair H100 Cooling Mod - YouTube
ZawLee
I got a better idea though. But portable aircon worth 800sgd and put it facing the side panel with door removed and replaced with dust filter as a door panel. You know what I am saying right?
Honda_
How is the air flow of corsair 330r casing?
Is there a window version of this casing?
DeenzX
But then you would be able to see spinning fans anymore :s13:
DeenzX
Honestly, why would you put a cover over your intake fans and obstruct airflow? Apparently, this case did it for aesthetics..
killerslayer92
MORE FANS!
anyone can do the math for the airflow and airpressure from 40 fans
might hv to put warning label
