artyboy
- Jul 7, 2002
the two side fans are CM ones?
Nope they are Zalmans. All the other fans are transparent CMs but they are heavier than the Zalmans - not as good for tying to the chasis with cable ties (although I think still doable).
At most only corrosion or indirectly cause shorting due to other extra elements but never directly due to humidity or even moisture one lah haha.
