WussRedXLi
- Jun 15, 2001
Currently Xiaomi Air Purifier Gen 1 is on offer, S$115 / S$129, I am tired of AX40 due to the need to clean the pre-filter which collects alot of lint that I find a hassle to clean.
My question, if any experts here can enlighten me:
1. Is there any pre-filter I need to clean on XM1 or XM2?
2. Can XM1 and XM2 stay on high mode 24/7? I read that XM2 will auto revert back to "auto" after certain time, but not XM1.
Why is XM2 favoured over XM1? My main concern is XM2 cannot stay on high mode for 24/7 (like my AX40).
Thanks!
There are prefilters on 99% of the air purifiers out there. This is a plus point actually. There are also very similar prefilters on 100% of the aircon FCUs out there. It's just a 20 seconds job with a vacuum cleaner, i do it whenever i vacuum the floor coz surely would pass by the APs.
If no vacuum, just go to the shower or service yard and blast it with the shower head/hose. shake it a bit/pad it dry with a cloth, install back. If you want you can air dry before installing, or just install it while it's still a bit damp.
Yes, there are "net" prefilters on the XM1 and XM2, these are located on the cylindrical HEPA filter units....it's "built in".
If there are no prefilters, all that lint would be stuck on the HEPA filter's pleated surface and it won't be easy to vacuum it then. You'd be "using up" that HEPA filter like 10X faster than it ought to be.
Aircon FCU pre filters, a bit lehceh, need to use a chair so not cleaned as often.
(no longer have them now) .
