Region set to China on your app?just bought the pro and cannot connect via mi home apps.
had reset a few time and it just cannot detect the air purifier.
Any suggestion ?
Wifi on 2.4GHz ?
Any suggestion ?
How is Xiaomi AP Pro? I am using Honeywell 17007. Looking to buy another one.
Buy the air purifier which gives out negative ions and can kill mozzies like from SHARP
https://sharp.com.sg/web/products/CatLev3.asp?Catid=5
Bought sharp AP so far so good.
Is the mosquito catcher effective?
Must we change the filter often? How they catch the mosquitos?
wats the best price to purchase Xiaomi AP 2S or pro?
thanks in advance.
On a daily basis u guys use which color de filter? My toddler niece is always coughing and i want to buy one for her to try...
Xiaomi Gen 2S is not expensive on carousell.which one will you choose? i can only afford this price range......
Philips air purifier 1000 series ac1215/30
https://www.lazada.sg/products/philips-air-purifier-1000-series-ac121530-i153109577-s191147046.html
or
Xiaomi AP
https://www.lazada.sg/products/xiao...ml?spm=a2o70.10453684.4.1.61a549d7jnEY6O&mp=3
Go for the Xiaomi gen 2 AP, ease and cheapness of replacement filters.
Gen 2 is probably a bit better in certain ways for our SG rooms as it has a smaller footprint etc.
If budget is tight, another option is picking up a relatively new second hand from carousell.
Some have scored good gems for not much money, eg I picked up a literally brand new (1 year) Samsung AX40 at just 80 dollars (SG retail $450, qoo10 get for S$270). Another pax i remember got it at $50 only. It's a 320m3/hr machine with good noise performance when on original samsung filters, TB filters at about $6 per piece turns it into an approx 240 m3/hr machine.
Use it at max speed of 240m3/hr, not that noisy.
Replacement filter just go Taobao pickup filters that more or less can fit, then plug up the gaps with bubble wrap or plastic wrapping.
Downside is more work on filters search (buy in bulk), second hand AP = opening it up to clean with rubbing alcohol or something to get rid of any smells or what (ABS wont be affected no issue). As good as new. The Samsung AX40 is a workhorse that will last many many years, so are Sharp APs.
Will work, trust me, we have done the measurements.
Xiaomi gen 2 AP
Samsung AX40
Sharp APs
Which one most quiet?
Is it all about same cleaning effectiveness?
Is Xiaomi gen 2 AP most value for money?
If too noisy I cannot sleep.
Thanks.
