Air purifier? - Part 2
Rio de
Samsung AX40
hi
I looked thru the long thread and saw the recommendation to buy Samsung AX40. However Qoo10 no longer sell the older model AX40H5000GMD. It now carry the new AX40M3030WMD which is SGD428.
Also found a Qoo10 subsite under goniglobal which sell the AX40K3020GWD for SGD320.
Does the new AX40 as good as the old AX40? Do they share the same filter?
I am also concern about ionizer function. Does the old and new AX40 support disabling Ionizer?
Hopefully AP experts can advise please.
kimsix
Does the ion produced in your machine makes the air smells fresher?
someone wrote at low speed can hear the zizizizizi noise if working. my sounds have. in small hdb bedroom, i feel the air now smell closer to my office that uses high end APs, and aircon seems cooler, so i guess it is doing some filtering.
for $88, the build is simple and ok, no filmsy parts. high speed is audible whooshing, night mode is silent but not sure is useful filtering. i tried haze mode and set 8 hours timer. The air output seems directed a bit towards back, so i faced the backside front since placed it near wall, a bit eyesore to see the mesh vents but more practical.
our local version do not come with carbon filter, so bought a $30 3M filtrate pack, i think can last 4 changes if change every 4 months.
:s12:
WussRedXLi
Hi all. Like to check for Xiaomi model AC-M1-CA. Going at $99. Is this a good deal?
That's the first gen right? What, so cheap? It's a very good deal.
Issue is, it's a bit on the large side, even though the "main" dimension is the height and the actual footprint is not that big. However, it's still quite a bit visually imposing.
But i reckon it might be useful in big landed properties, mansionetts (eg tucked under the stairs) etc.
If new BTO, i think can forget it.
WussRedXLi
Was sharing this with another member in a PM. Posting it here as well....
Other than haze, dust mite droppings, another common source is mold (from aircon FCU).
https://inspectapedia.com/indoor_air_quality/Airborne-Particle-Size-Definitions.php
100% there is some stuff in your aircon FCU. If you are interested you can search the DIY aircon cleaning thread in EDMW, i posted a fair bit of info there.
But here's a picture of my FCU before i learnt to clean it (Always did some very light DIY cleaning/wiping/vacuuming myself and also every ~ 6 months call for $30 type general cleaning, useless one, and 2-3 years alkaline chemical cleaning is way too hardcore for the aluminum fins, they are maciam like drain cleaner kinda pH).
This is my aircon FCU drain pan, i took it out and ran 95% denatured alcohol on it and rubbed with a cloth. Took out about 98% of them.
Obviously, the $30 type of servicing is not very thorough and is mostly extrinsic/external.
Some allergists have told us that they can tell by the nature of a patient's complaint what they're probably allergic to and what size and types of particles are in the patient's environment. When inhaled in a breath of air, these comparatively large fungal spores are more likely to be trapped in a person's nose.
If a patient has chronic rhinitus, for example, they may be responding to large mold spores like Alternaria sp. which may be as big as 15 x 50u. If a patient has lower respiratory complaints (pulmonary or in the lungs) they might be responding to very small mold spores like some of those in the Aspergillus sp. or Penicillium sp. size range, which we often see in our lab can be down in to the 1u range in size. The photograph shows some Alternaria sp. mold spores which are pretty big.
xiaoleo8892
Can get the filter from Sharp Service Centre (438B Alexandra Road) or Qoo10 (some local sellers have).
For me I'm currently using brandless hepa filters from taobao recommend in this thread, gotta scroll back and read. They are a generic size, don't fit exactly, so gotta DIY abit to fit. Think okay for general daily use as I'm using these in the rooms that are not bedrooms. Study/living room.
Anyway just to share, I came across this seller in Qoo10. The seller is selling filter that are usually hard to buy at 40-50% cheaper than retail price. Tried their hepa and carbon filter which I feel are of good quality. Seller name is Home Labz. Type Home Labz in Qoo10 and should be able to find their store.
Saw this seller in lazada and carousell too. All positive review from past buyer. Guess can save some money on filter replacement and replace them more often now.
Lucky177
I have bought all 3 before. The pic shown in previous posting is green.
In very brief:
Blue - original (the most basic)
Green - is enhanced type with additional charcoal (thicker than the blue and purple) to remove odor etc
Purple - Antibacterial version. Thickness similar to the blue except is in purple (antibacterial layer)
All can use but filter bottom better to have RFID sticker else purifier might prompt u pls use original filter. But still can use tho’. So if in doubt, check with seller or see reviews if there’s any RFID sticker on those filters.
What color filter u buy? Confused between blue, green n purple filter replacement.
free2d
In very brief:
Hmmm....Now using stock blue came with the Pro for bedroom with baby. should between green and purple then?
Lucky177
Usually for bedroom I don’t use the green one. I only use for living hall. When you change to green ones, at the beginning there could be a very tint smell - probably due to the charcoal.
Bedroom I’m using either the stock blue ones (until I finishes them) or the purple.
Blue one should be fine. Next time when u need to change, can consider the purple one if u prefer. I don’t know how effective their antibacterial tho’.
PhoenixRising
Anyone using samsung ax40 air purifier? Looking for true hepa filters replacement. Anyone had good recommendation for sellers
