Air purifier? - Part 2
dnsfpl
which xiaomi air purfier to buy?
which model is uses True HEPA filter?
frozyfrozen
After reading some of the comments above stating that xiaomi need to set different region sg/china. May I ask what is the difference when selecting location? Because I wish to get a roborock and pair to the app together with xiaomi purifier max. Will there be any issue?
batniss
Set to china in app instead of SG.
Im using the xm pro purifier. It is extremely quiet
frozyfrozen
Yes I have read that even the Max version is quiet and has a very high filtration rate. I think either pro or max is not sold in sg right? But lazada seems to be cheap.
So I assume that location doesn't make any difference ay?
Thanks for your reply btw! 😁
batniss
Thanks for your reply btw! ��
No idea, i bought it from Qoo10 though.
yup, doesn't
nagase_4
I recently also just purchased the Roborock and Xiaomi Air Purifier 2S.
Both are set to SG regions. No need set to China.
I was surprised though because alot of posts stating that xiaomi air purifier cannot be registered to SG region, only can register to China region.
I checked with the seller on Qoo10 and he mentioned that the set i bought (those he selling) are international sets. That explains.
frozyfrozen
Ayy thank you for your input. May I ask which store you got your 2s from? Im eyeing on "1stShop" on Qoo10 now and is waiting for the 1111 sale. I should be getting the pro version instead because I can't find Max version's filter anywhere somehow.
nagase_4
Yup, i got it from 1stshop too.
https://www.qoo10.sg/item/XIAOMI-EN...SE-APP-CHECK-AIR/422184869?selectedOptions=;;
Do whatsapp the seller and check on stock availability first though.
When i purchased my purifier, I thought they had ready stock but they didnt have probably because they just sold out.
In the end i waited for 2 weeks before my purifier was delivered.
kimsix
https://www.qoo10.sg/item/SHARP-SHARP-OFFICIAL-PLASMACLUSTER-AIR-PURIFIER-FP-J30E/629725165?__ar=Y
Bought this $88 sharp air purifier, specs say is hepa, shorter height and comes with plasma ion?
how is sharp brand now?
*1 Recommended room size; Measured based on the JEM1467 standard of the Japan Electrical Manufacturers’ Association)
*2 Size of a room in which approximately 7,000 ions can be measured per cm3 in the centre of the room (at a height of approximately 1.2 meters from the floor) when the product is placed next to a wall and operated at the medium setting.
*3 HEPA is defined by Japan Electrical Manufacturers’ Association Standard, JEM 1467. The filter removes more than 99.97% of 0.3-micron dust particles.
*3 At a smoking rate of five cigarettes per day.
PunggolLRT
Also bought the same model few months back. I think Sharp no longer made in Japan, but mainly in China and Thailand.
Service centre in AMK (near AMK fire station). I went to get a replacement part for my Sharp fridge and it’s the same service centre for Sharp AP too.
kimsix
How much you buy it for? Cant find info about this model, but seem is low cost high volume model for india market.
This cheaper than even xiaomi but have the necessary hepa filtering, good for basic use since design is just a fan to suck in and blow out?
hepa replacement about 2 years and cost $60.
PunggolLRT
I bought it for 149 , after $10 coupon form Sharp Offical Store on qoo10.
I think now they have sales for this model.
Just a basic model, suck in, go through the hepa filter and blow out. IMO, it’s good for basic usage in my BTO master bedroom. And it’s very silent on sleep model.
kimsix
good to know it is deal now, will get another set for living room, almost same price as the replacement filter.
basic is enough as long is hepa certified, sometimes too much features and electronics spoil easier. :s13:
