Air purifier? - Part 2
Zenden0919
free2d
Usually for bedroom I don’t use the green one. I only use for living hall. When you change to green ones, at the beginning there could be a very tint smell - probably due to the charcoal.
Bedroom I’m using either the stock blue ones (until I finishes them) or the purple.
Blue one should be fine. Next time when u need to change, can consider the purple one if u prefer. I don’t know how effective their antibacterial tho’.
Just asking, not try to be cheapo. Can clean the old one using air compressor/wash etc like AC filter?
free2d
I searched YouTube will give it a try on weekend. Before i spend on new one.
https://youtu.be/SqMtX8R1xSc
djfalcon
Hi guys, I just received my Xiaomi air purifier 2s, use it for a night and realised it was emitting plastic weird smell, is it normal for first time use?
free2d
Just cleaned my Pro. But i can't reset to 100%. It still shown 25%. Is it got to do with the RFID?
TimmyWimmy
There's a button you gotta press and hold at the back of the air purifier. It'll beep and then reset on your app :) I think it can be found online too! Just Google it
free2d
I did. Cant reset to 100%. I suspect i didn't wait until replace filter warning to come out. It gives this 智能淲芯,无需重置.
Lucky177
I didn’t wait until replace filter warning to come out before changing to a new filter.
Press the back button for 6seconds until u hear the beep sound. It should reset your new filter to 100%.
android
Any recommendations for xiaomi purifier air filter replacement. Should I get third party of original?
feetlebrash
May I know if xiaomi 2s is the best in xiaomi’s range so far & its difference from the xiaomi Max & xiaomi Pro is just CADR only?
How is the Xiaomi 2s compared to the Samsung AX40?
Actually I’m looking for something to kill flu & cold virus in office, is looking for purifiers not even the right use case? Should I get an ioniser, should I get an UVC irradiator?
free2d
2S, Pro n Max, difference are small medium large areas/rooms/volume.
I think Max got different filter element? Cmiiw.
xecuter
thinking to get the xiaomi air purifier but want to scent the room as well.. any suggestions? read from earlier post not recommending to use essential oils with AP..
Lucky177
If have to use, then alternatively is do not switch on the air purifier when using essential oils and vice versa. Not both at the same time.
