Air purifier? - Part 2
Janet90
Anyone know where to get cheaper Europace air Purifer filter replacements beside online store? Realised that local stores no longer carry them anymore
TIA
soufool
Currently own the Xiaomi 2S..So far ok but having issues connecting to the app. Starting ok then suddenly "failed to initialize" device so can't control the custom settings. Level of dust in the room has been reduced moderately which was my objective.
Personally feel the auto mode doesn't do much (very weak), need to manually adjust to higher setting for it to work properly. Think there's an article out there in google that highlights this issue.
Overall still an ok purchase as good price and easy to find filter.
free2d
I set all my xiaomi ap manually between 25-50% fan. Was wondering how does the auto mode algorithm works.
Lucky177
I don’t use auto mode either. Same goes to my other brands of purifiers last time. Also didn’t use their auto mode. Feels “weak”
But for Xiaomi purifiers, in order to adjust favourite fan speed mode, got to use the mobile app. Minus point imo. :( Would be much better if it could be adjusted on the device itself even tho’ I only set the speed once - during setup, after that I didn’t adjust the speed anymore. :s13:
soufool
Urgh damn annoyed that it can't connect to the app now. Tried resetting the wifi on the device etc but still doesn't work.
Bamboozle
Hi can i know if anyone purchases Xiaomi 2S's filters online? Possible to share some recommended sellers? Thanks!
luv_boa
So usually what PM2.5 readings are u guys getting within your home before u start the AP? Mine is usually 30/40 plus even though NEA's public readings are 10-20 range? :s8: WHO guideline is 25 for 24hr period and 10 for annual mean.
I will rev up my Xiaomi AP until PM2.5 reading drops to about 10, then turn down the speed to acceptable noise level, before I go to sleep. :D
Hi, can check with you what's the lowest reading you got? Mine rarely shows above 20. I can get reading of 1 actually. Wonder if my sensor is faulty?
Lucky177
Qoo10? Taobao? Can compare price ba.
I previously bought my filters at Qoo10. Local sellers, not those oversea sellers. No specific seller. Depends on which one got promo or better pricing or seems more reliable/efficient in shipping.
Lucky177
That day my purifiers also auto became offline. :s22:
Tried the usual setup few times cannot detect. Reset purifier—> Add purifier in app —> Toggle to phone settings to change to purifier wifi —> Toggle back to app to continue setup. :(
So I go try the other way. Reset purifier —> Goto Phone settings first and select purifier wifi —> Launch the app to add purifier ... somehow it works. :s22: :s13:
soufool
I managed to solve the issue! Gotta reset purifier wifi, and when reconnecting the region selected has to be Mainland China, not Singapore.
soufool
My PSI reading is always around 10 in my room, and drops to 001/002 very quickly. I stay in the east, and recently the smoky smell caused it to read about 65. When people burn paper downstairs it also goes up to 30. Thats when I knew it was working.
luv_boa
Same I stay in east. Nv see it goes up above 20
Jerineng
CanT_Make_IT
I have a Honeywell Air filter 18250 but after I change the filter. I can’t turn it on.
Anyone encounter the same issue before ?
vofzxy
Lucky177
Didn’t encounter such issue before (when I had my Honeywell purifiers).
Try unplug & plug back the power plug? Maybe loose?
