Air purifier? - Part 2
whoooo
Sorry need spoonfeed. Can recommend HEPA replacement for AX40 from taobao please. Thanks alot in advance.
kpo here.....i repost the link for last year provided by either Bro Wuss or 1 of the guys here. read properly I repost and not link/earn from this seller
http://world.taobao.com/item/522668837488.htm
Hi ,for xm gen 2 ,isit good ? As in able to work against those tiny particles frm haze and hw often need replace filter ?thks
err dont buy Xiaomi as from EDMW anything xiaomi will explode and they churn out rubbiush product because they are tiong product.....
joker side Xiaomi AP2 is advertise as Air Purifier lei bro, also u see here many pp incl me also bought it , price wise depends on where u buy it i.e Lazada, Qoo10, Taobao etc. I paid around $160 as we combined ship in 12set lol
Kinetic
Any lobang to buy xiaomi version 1 air purifier filter?
version 1 or 2 use similar filters.
Any lobang for xm2 filter?
Looking for xm filter also, saw so many in taobao and prices vary so much, got confused which one is authentic or even oem which is reliable.
Anyway, can i tompang if anyone is buying from taobao? my mandarin cmi
WussRedXLi
tildveryn
Can air purifier work together with electric repellent (liquid diffuser type)?
Would the purifier absorb the smell of the repellent? then the repellent will lose the effectiveness?
patcheon
shorten usage life of hepa filter only
I thought maybe will shorten life span on AC filter and also the formaldehyde filter (if present) if the vapour is being absorbed by those. Not sure if not sure if the vapour particles are be big enough to be trapped by the HEPA filter.
Had also wondered if turning on the AP would reduce/remove the effect of the electric repellent too and waste the fluid used up during the period when the AP is turned on.
class
What kind of smell? If it's bad or musky smell, it's time to change the filter. Bacterial has already taken over and please, don't vacuum your filter. Unless it has a pre filter, there is very little effect in vacuuming it. You may be expose to more dust than you need to be.
pre filter is the thin filter while the hepa is the thicker one right?
i vacuum the thin one.
