Air purifier? - Part 2
whoooo
Air purifiers in online stores are selling fast.. This morning I saw some air purifiers on Lazada and Qoo10 still got stocks.. but now I check again sold out liao.. :eek:
typical knee jerk reaction by stinkies. last min haze all go snap. tmr the haze will be mild and pp will be complacent again.
kandinsky
Why will you want to buy a humidifier?
Wet air will create more air borne bacteria, more stuffs to moldy, electronics to fail, and make the person feel sticky and hot. SG RH is already around 70%.
You should be looking for a dehumidifier, it reduce to humidity to healthy level but it increases temperature at the same time.
I think it's because some people find the air from aircon too dry. E.g., They'll cough cos throat too dry, etc. So they get humidifier to use in aircon room so that the room can be cold and yet not too drying.
urbanathlon
I on air con, the RH is still around 50%, actually then is the correct recommended healthy level.
However, if the air con is placed directly infront of the bed, the air blows straight to your face while you rest, then that's a problem and yes that aggravates throat irritation.
I will spend the money to shift the air con to another location or try tilting the air con's vent away. Humidifier, is still not a wise idea. Humidifying, will only make you feel hotter and cause other issues, even if the temperature shows lower. As you can't perspire properly to cool yourself, due to the high density of water in the air.
I ever tried at RH40%, temperature at 31 degrees.
I dont feel uncomfy at all. No sweat.
Lower to 30% rh, 28 degrees feel pretty cold.
It's the humidity more than the temperature that makes you feel hot and stuffy.
Dehumidifiers can be purchased from TB at i think $100+.
Should be the same for humidifier too if you really need it.
Dehumidifiers need to drain out water. ( I had one full tank of 1 litre in around 3 hrs iirc.
Humidifiers need to top up water.
nuky8181
Yeah. Is for office which is too cold and dry hence looking for a humidifier. Anyone can recommend? I think this thread is the closer things i can find already.....
WussRedXLi
Alamak my XM AP2 now can't connect to my network keep blinking, wifi reset also can't connect. Any bro using face same problem?
Power off both Wifi router and XM2. Power on Wifi, wait 2-3 mins until stable and got net access (confirm via PC/phone). Then power on XM2.
_DeS__
Sorry need spoonfeed. Can recommend HEPA replacement for AX40 from taobao please. Thanks alot in advance.
NWT1978
haze arrived... so everyone rushed to get it... :s12::s22: fastest finger and fastest checkout win =:p
XM one all sold out? NTUC also no stocks liao.
haze arrived...everyone rushed to get it... preorder it but need wait for stock...
No stocks here also........checked just now at 7pm.
I checked on Wed, there were at least 20 pcs of XM1. heh.
All unwanted since many months ago.....
now they are selling like the Taiwan milk tea due to haze... which now tea being recalled... :eek::s22:
whoooo
Reset afew time also cannot, I factory reset the router as forgotten the admin password, once done thevXM connect to it with no issue
greythorne
Why no one talk about Dyson fan+air purifier? It's pretty ex but what so special about it compared to all those China brands?
class
I vacuum the filters but the air purifier still has a smell when I switch it on.
Anyone face the same problem?
uRiZEn
Experts
The Panasonic Plasmacluster Air purifiers FP-F30E good or not? Dunno how to see and mainly to be used in bedroom. Likes it that it can remove pet odour.
Thanks in advance
xyz_sg
Can anyone share their experience with Tefal PU4025? I bought one today, however it is creating more noise when I change the fan speed to lowest, night mode. The noise is due to the motor, although the noise due to airflow is reduced, motor noise is increasing with low speed (I hear similar noise (increase/decrease with ~2 sec period) when the motor is running at medium speed). I am thinking that I got a defective one...
extemporisation
Anyone knows the China model number that corresponds to Sharp KC-D40E? Thanks! Looking for replacement filters on TB...
