Air purifier?
chuanz
Smoke out since 1600h just now. Fairly bad @ 1800h. 2-3km visibility.
My PM2.5 monitor (senses down to 0.8 microns) also showing elevated readings.
The wind has been blowing SE/SSE the whole day long.
How come there is haze, somemore fairly bad? (shd only get that when it turns SW and blows part of it to us).
Need to check the satellite photos later.
17 Sep... SE direction. Check the diagrams.
Weather History for Singapore, Singapore | Weather Underground
Some how.. yeah... but no smell... weird
WussRedXLi
Different types of trees/vegetation burned.... :s22:
But seriously, peat puts out a big part.
For those interested, there is this thing called Fire Danger Rating System/FDRS by ASEAN Haze Action Online.
Look through all the diagrams. Currently it's near impossible to put out the fires esp for Southern Sumatra.
Check the FFMC or Fine Fuel Moisture Code.
But theorectically there should not be any Severe dense haze, check the DC or Drought Code.
WussRedXLi
Drought Code
Drought Code (DC) | ASEAN Haze Action Online
The DC values shown on the map are indicative values of the moisture content of a deep layer of compact organic matter. Peat soil is an example of deep compact organic soil. The DC is used to indicate the potential for fire to smoulder in peat which is the primary cause of smoke and haze in Southeast Asia. It can also be used as an indicator of difficulty in extinguishing deep burning peat fires as well as an early warning indicator of serious haze events.
Fine Fuel Moisture Code (FFMC) | ASEAN Haze Action Online
The FFMC values shown on the map are numerical ratings of the moisture content of litter and other cured fine fuels. The FFMC indicates the relative ease of ignition and flammability of fine fuels. Thus, the FFMC is used as an indicator of ignition potential or the potential for fires to start and spread in the area. (Fine Fuels: Slash fuels, grassland, lalang, bushes etc).
WussRedXLi
Will know in time to come if the haze is coming from Kalimantan as well, mixed with some Sumatra.
That's a damn huge patch of light haze.
The wind is still SE now. In fact, quite a few hours today actually were ESE, ie def not from Sumatra direction. The haze from Sumatra should not be affecting us at such levels.
IF this is true, high chance that the haze will persist for quite a few days.
Kalimantan is way worse than Sumatra.
Kalimantan wind dir is EAST, directly towards Singapore. And with it being 700+km to 1400km away, there is more than enough space to spread out over an extremely large area.
Just that the intensity won't be high (barring 1997's PSI 226 haze, which was from Kalimantan also)
WussRedXLi
Pickup @ Liang Court.
But I don't think they have ready stock of 150pcs (that's a lot just to warehouse them esp with high rents nowadays). Prob just fufil order of 100 then they get, and then distribute.
mosmos
High Honorary Member
tik hab, rast sat gos ledeem sgd12.50 Iona 16" fan and asus fonepad sgd125, sell more than 300 oso got stocks ~
mosmos
good price a not?
feel like hooting a small one for my study leh.
wrx bro - this one eh sai boh?
rast time buy at xtian mall sgd88 few yrs ago but nvr seen any stalls selling below sgd100, but tik only pink color got this sgd99 price~
chompchomp
Whats the best for a cheap n good for a room.. ?? Waking up with sore throat not fun
WussRedXLi
That Sharp one that mosmos has posted loh. Sharp A28.
It's HEPA10, but it'd work for HDB bedrooms even at PM0.1 (haze particle size, some haze are below this size actually as tested by China before), absolutely no issue at all.
Keep your room windows and door SHUT, for current conditions it's best to keep it 24/7. It's 48W consumption, not ex for electricity......
I have a feeling that this will go on for another week.
Wind is still SE @ 18kph for Singapore. Palembang and Jambi all also SE. Past few days also didn't have S winds.
Turn to S or SW we all really will get it, it will be way worse.
Singapore history for 18sep today.
http://www.wunderground.com/history...tml?req_city=NA&req_state=NA&req_statename=NA
chompchomp
Whats the difference of hepa... got cheaper ones? :x
WussRedXLi
Cheaper ones would be taobao HEPA filters (about SGD10) + SGD16.90 morries fan @ Japan Home liao. They will also work decently.
However they won't reach you in time for protecting you and your kids against the haze. :(
That said, tonight i gotta pick up 2pcs of the SGD16.90 morries fan myself.
