Air purifier?
WussRedXLi
Tradey...im at taka BD and the A40 is 429. A50 is 529. D40 is 459. A80 is 549.
A80 used to be 499 just last week.
Maybe can go GAB liao..if you aim A80.
Dont have D50.
The good thing about Best Denki Taka is that you can check out all the models, plugged in/powered on and listen to the sound and feel the output.
The Samsung AX022 and AX041 are also plugged in for eval.
The Samsungs are definitely less noisy and it's fairly noticeable.
tradey
Dont have D50.
I just got back from Parisilk katong. Bought the Sharp d40, at 449. Now thinking whether should get Samsung Ax40 for living room. Ax40 and Ax041 is different right?
Also my study room now using Philips AC4002/00. But the filterS cannot make it liao. Anyone got lobang to get replacement filters?
OldTech
Have anyone tried Whirlpool 37.4m² Air Purifier AP628W? It's the one rated the best by Case SG.
But my concern is finding a replacement filter after 2 years down the road. This model seems to be specially being sold in Singapore only. No overseas online store has been selling this and any replacement filter.
WussRedXLi
5PM Haze alert for South.
57 ug/m3 PSI 102 AQI 152
Shower alert for South. Mixed with Haze.
WussRedXLi
Samsung AX40 and AX041 are similar, just one is 220V 60Hz and the other is 240V 50Hz. Both appliances can work in SG...AX40 stress tested also.
Philips filters, can try Best Denki, but i reckon won't have your model.
Else can try taobao and DIY cut. Just get a bigger piece than your present filter and then slice it up, tape up the sides to reduce bypass. Note the depth also.
But my concern is finding a replacement filter after 2 years down the road. This model seems to be specially being sold in Singapore only. No overseas online store has been selling this and any replacement filter.[/IMG]
AP628W only 299 approx, ok deal.
Filter can DIY cut, get one that's bigger and slice it to size. Tape up the sides with tape/foam to reduce bypass. Note the depth also.
WussRedXLi
As of Sep 1 - Oct 20, 45 days were above WHO daily mean of 25 ug/m3
26 days were above US EPA Unhealthy level for Sensitive Groups of 35 ug/m3
Tech_Freak
Is there any latest research that says ionizers in air purifiers will do harm to your health (ozone)? All those I read are pretty old, 2005-2007.
vodka_water
Can i have the url for the hepa filter? Need too buy for my ax40.
chuanz
Also my study room now using Philips AC4002/00. But the filterS cannot make it liao. Anyone got lobang to get replacaement filters?
AC4002 original filter can get from Philips Toa Payoh. Not cheap though. Remember mosmos posted during Isetan(?) sale half price.
Other option is the usual cut to fit.
WussRedXLi
Unless I'm missing something, I'd get 3 units of AX40 at a quarter of the price and distribute the 3 units over the large area...
It's like Samsung or any other manufacturer's flagship 80-90" 4k TVs.
Don't think a practical person even with 3 mil in his bank would buy such a thing. :D
