Air purifier?
WussRedXLi
Can i have the url for the hepa filter? Need too buy for my ax40.
AX40 is 12" by 11". The HEPA filter depth is 1.5", while the activated charcoal is 0.5 inch (2.0 inch total). H12 or H13 would work.
H13 HEPA_
TB got some delay issues currently at HK customs. Check the Official Taobao thread Part 4, ask your 4PX forwarding questions there.
I used this taobao filter 3 days ago's haze, just 10 hours nia from pristine start conditions.
WussRedXLi
One big reason why China has so much of these H10-H11 grade HEPA which are lower cost is because it's a prolonged perennial issue there + PM2.5 concentrations are like 3X higher than what we have been experiencing for nearly 2 months now.
Also, obviously, the HEPA filter cost : salary ratio is lower than us.
So it's not easy on them. Even KN90 or N95 masks can add up to a significant cost for them.
WussRedXLi
again...it raining here so wont be that bad... I hope...
Don't have liao. Just now for about 20 mins it really was a bit smelly but not the woody burnt smell. I walked out to the corridor a distance away and it was the same so I don't think it was local.
plasticpistola
BTw, can check out the Stadler air purifiers (swiss made) @ Robinsons Orchard. They are really décor friendly in a contemporary designed home. :)
I saw this the other time @ robinsons and wah really v chio.
oso saw this floor fan with the frame made out of wood, damn swee but I thk kan ex.
Btw today air not bad hor? Can go running liao!
LightBuzz
Hi I just bought nap501 yesterday, however the sensor light will turn red and change to turbo for auto for the whole day even through I don't smell any haze or dirty air. Even my 611 are still in blue. Is it normal? Thanks
chuanz
NAP501 sensor is like that. Probably the threshold was set too low. Suggest to use manual speed setting if it bothers you too much.
WussRedXLi
The novita sensor short short one...
WussRedXLi
WussRedXLi
Air quality not toooo good this morning again, very slightly haze.
Since Sep 1st + 1 week in March, can really say we are approaching long term for the whole year's duration already.
wizardundo
I thought I smell something funny in the air from 5am to around 6am.. fall back to sleep after that :s13:
WussRedXLi
23 Oct 1745h and it seems like the areas near Palembang have no big visible plumes of haze already. (the Regency name is called Ogan Komering Ilir Regency). Province = S Sumatra
plasticpistola
Good morning wrx bro!
Means they stopped burning liao or they've been getting a lot of rain to put out the fires?
WussRedXLi
Good morning!
I think past few days there was some light rain. The fires have not been put out totally as the NE monsoon has not arrived yet. These are peat fires, and in Sep it did come back just after 2-3 days after a day of showers and the hotspots did go down.
So don't bet on anything yet, as they did say the Sumatran squalls should have started last week? :s22:
According to the Indonesian authorities, you'd need at least 7 consecutive days of heavy rain. ie say heavy rain at least for several hours? Not the typical light showers for 30-60 mins. The peatlands need to be totally soaked or even lightly flooded.
