Air purifier?
WussRedXLi
Hi guys, I intend to get an air purifier for one of my bedrooms. Being checking out the stores ans spotted this brand IFAN model no IF3232 selling for $199. This is my first time buying one, so would like some opinion abt this particular item. Thanks.
http://www.ifan.com.sg/ifan/if3232
SGD199 is a decent price for that. Replacement filters need to source from taobao i guess (either you customise from a seller or you get existing ones and DIY cut into size). the IFAN is simialr to the Novita NAP501i
Though i'd prefer you get the Samsung AX40 or LG LA-Q379SB, latter is SGD278 FedEX shipped qoo10.sg. More powerful and branded.
laironpark
Hi, thanks for your help, will do a check on the suggeated Samsung and LG models
WussRedXLi
Shanghai air quality page > NEA also. (other than Thailand's aqmthai.com)
WussRedXLi
I got another batch of Taobao HEPA filters for my LG PS-R459.
Stock LG HEPA is 360 x 340 x 31mm.
Taobao HEPA I customise as 361 x 342 x 45mm. Material is the cheaper polypropylene that gives higher resistance but efficiency is still decent at 97% as measured by my laser partice counter.
Measured airflow by my anemometer this time round (at one particular same spot).
LG stock H13 = 21.36kph
Taobao HEPA = 22.20kph
RMB140 each for this customisation
http://item.taobao.com/item.htm?spm=a1z09.2.9.64.hQ2Xq3&id=20676620186&_u=31u0hcib77e2
LouisSaha
Intend to get sharp air purifier for my bedroom.
Is the model FU-A28E good?
So if i on air con can turn on together with the air purifier right?
WussRedXLi
http://www.straitstimes.com/news/si...slight-haze-singapore-friday-evening-20150403
Slight haze in Singapore on Friday evening
Published on Apr 3, 2015 8:28 PM
SINGAPORE - Slight haze clouded Singapore on Friday, as the three-hour Pollution Standards Index (PSI) rose to 86 at 8pm. The 24-hour PSI reading was between 56 to 62, according to the National Environment Agency's (NEA) website. The 3-hour PSI reading rose above 60 at 2pm on Friday, and went up steadily throughout the afternoon. Both indices are in the moderate range.
WussRedXLi
Noisy leh, in high fan speed mode. Medium speed is probably the limi for average sleepers. Light sleepers would find it noisy even in medium. Then they complain the air purifier doesn't work for their allergies etc...coz they leave it in low.
LouisSaha
Noisy ar? Then any recommended models?
Budget ard 300
Panerex
Took out the filters from my novita air purifiers for some cleaning today... Just from visual, how do I know the hepa filters are due for replacement?
Thanks
chuanz
Haven't seen such crystal clear night sky (right after the earlier showers) since December!
chuanz
Thanks
May be difficult to determine if HEPA filter needs changing from visual. It may be darkened from normal use but it'll continue to function.
WussRedXLi
Central spike to 58 ug/m3 PM2.5 detected for 1700hr reading (1600-1700hr period)
West South East 46-49 ug/m3.
My meter registering 50-55ug/m3 real-time.
WussRedXLi
They have a bigger version, SGD308 + $45 shipping. 37 sqm but airflow spec unknown.
I guess it's good for those who have modern contemporary décor and want a nice one to put in the living room or MBR, but hiam current Air Purifier designs to be too cold/utilitarian.
circular replacement filter don't know if can customise or not, though I know taobao got circular ones.
