Air purifier?
chuanz
Anyone using this? Spec seems kinda good for the price but not really sure if it's worth it.
http://list.qoo10.sg/item/2015-AIR-PURIFIER-SINGAPORE-BRAND/428257530
Same item asked by somebody else last week ;)
Anyone tried this? Reviews?
Replacement filter available from Taobao? :s22:
Replacement filter can get from them. Or customise the size from TB.
This one has too low an airflow. It's just nice in high speed for small BTO bedroom (5 ACH) but it'd be too noisy. It is small though. But if you want it to be small, go for the Sharp A28.
If you wanna get that, you might as well get this one. It's reviewed in the Chinese youtube video that I posted 1-3 pages earlier. 319 m3/hr measured.
Brand new in box
$120 - http://www.gumtree.sg/a-miscellaneo...or-120-usual-at-199/1001404078170910721075309
Sealed
$99 - http://www.gumtree.sg/a-other-healt...ier-kj30fenv-sealed/1001382187030910673161709
For the Midea/美的, the HEPA and AC filters are available on TB directly. Or you can customise.
JadziaK
Oh, you talking about this one.
It's better to get 3-4 pcs of Samsung AX40. Too loud.
Besides, it's impossible to ship over.
Thanks for sharing your views and answering all those questions posted by fellow forummers. � Took your recommendation & bought the Samsung AX40 from Daiso (Qoo10). At the highest speed setting, it still sounds quieter than my Novita NAP501. Only downside is this one doesn't have a timer so much switch off manually. To those who are interested, Daiso has been pricing it at $245 the past few days. Cheaper than the $269 I paid so now is a good time to grab one. Really value for money. HN in Funan was selling the AX041 for $399! I also ordered an extra set of Samsung hepa filter@$78. Me not the DIY type.�
Sent from LGE LG-H815 using GAGT
WussRedXLi
Thanks for sharing your views and answering all those questions posted by fellow forummers. ********* Took your recommendation & bought the Samsung AX40 from Daiso (Qoo10). At the highest speed setting, it still sounds quieter than my Novita NAP501. Only downside is this one doesn't have a timer so much switch off manually. To those who are interested, Daiso has been pricing it at $245 the past few days. Cheaper than the $269 I paid so now is a good time to grab one. Really value for money. HN in Funan was selling the AX041 for $399! I also ordered an extra set of Samsung hepa filter@$78. Me not the DIY type.*********
Great, glad you like it.
Don't use timer lah. I mentioned before, even if it's not for haze but for preventing allergies, you need it to be running at a decent airflow speed.
Power consumption is amongst the lowest out there, while at a great airflow. It's very efficient.
If one is still bothered by the very slight fan noise, just put some tissue into your ears during sleep time. :crazy:
chercm
If I run the unit 24x7 how often I need to change the filter ?
Working
Hi, to consolidate what i understand so far:
- Popular AP recommended: Samsung AX40/41.
- DIY filters: Good enough.
- Laser Particle Counter: The ones that were used in some of the tests here with screenshots (with Insan technology PCB) is no longer on sale. Next best is SamoAir or the compact version (two tier). I definitely like the display of the insan technology better.
Is this correct?
WussRedXLi
I'd guess still ard the same time but most likely 6 months confirm must change while if 12hrs you still can push to 9 months type. But that means a lot of aircon money as well bro.
It's about the smell of the PM trapped inside. Most apparent when the machine first starts up and you smell at the outlet. Even with the AC, it won't be able to do much (the AC should expire in 3 mths anyway).
WussRedXLi
Is this correct?
Yes. Don't waste money on the laser particle counter, unless you REALLY have a legit use for it.
Eg elderly parents > 65 yrs old (lagi got grandma > 90 yrs old)
Newborn esp pre-term/slight health issues. Very important point here. To them, in a relative sense PSI 100 reading is like PSI 200 to them (or more). Would you as a healthy adult like to be exposed to PSI 200 for a good few days?
Those with heart, lung and stroke risk issues. Very important point here.
Asthmatic kids/teens, coz even a short 1 minute spike can trigger/worsen asthma symptoms, like what happened yesterday morning in my South area in which my meter registered a bried spike to 212 ug/m3 while the baseline was approx. 150 ug/m3 and visibility dropped to 1.5km - 2km (NEA value is usually a fair bit lower, but that's ok as you can setup a relative value mapping).
You are sensitive, already experiencing any of the following : dry eyes, itchy skin, sore throat, running nose, headache
Allergic rhinitis
Pregnant. Fetus is growing the fastest in this stage of his/her whole lifespan, increase in size and weight is phenomenal. Cell multiplication etc. PM0.5 passes with ease into the blood stream. Etc.... Wanna risk it?
chercm
you mean to run this i need to turn on my AC , can't i use this with my ceiling fans ?
chuanz
You can use without AC, but with all the doors/windows closed, you're gonna find it pretty stuffy (due to high humidity) after a while even with the ceiling fan on full blast.
WussRedXLi
Yea like what Chuanz said. You can use your ceiling fans as well.
The technically correct answer should be close all the windows and doors for that room. Be it living room, bedroom, master bedroom.
Leave a bit of a 5cm gap for slight ventilation is alright. But the gap is either the door or window. Not door AND window gap of 5cm. The idea is not to have a strong steady stream of airflow from the outside get into the house/room and after that ventilate out.
It's like your air conditioning, do you leave the door or window open when it's switched on?
So yea, it's going to get warm if you do not have air conditioning.
Working
Allergic rhinitis
Thanks man, I've got a baby onboard. The particle counter is for..Erm...geek use. :)
WussRedXLi
Well if it's an infant then it's justifiable. After having more experience in using it, it's not that accurate in absolute numbers but it's extremely sensitive and repeatable in telling you the spot air quality at your place.
You can click the link in my sig for NEA 1-hr figures as well. But sometimes it lags a wee as well.
If you can afford it, it's a good buy. Besides, it'd be useful for the caregiver as well, I think you know the feeling, they simply cannot afford to be sick as well besides the baby.
This year El Nino is also very strong. ie very dry
chercm
where can i download the English manual for the Samsung AX40 air purifier ?
chuanz
No need manual... Only three buttons to operate.
- On/Off
- Mode select: Auto/Max/Min/Sleep (mode indicator lights on the right side)
- VirusDoctor (ionizer) on/off
sjchai75
Which better?
Anyone have experience of this Whirlpool model?
WHIRLPOOL AP628W
How is it if compare to Samsung AX40H5000GMD?
Thinking of getting the Samsung AX40H5000GMD from g-market, then saw this Whirlpool, selling $329 at Courts (Also with NEA reviews, seems good). So want to know which is better or more suitable to use.
