Air purifier?
HorseyPow3r
Just for reference, and if anybody else wondering when getting your spanking new AX40 and found that everything in the documentation is in Korean.
Buttons from left to right:
First four is touch buttons: On/off; Speed selection; VirusDoctor On/off (single touch) + filter change reset (hold a few secs); Child lock (hold a few secs)
Last four is speed indicator: Auto; High; Low; Sleep
Lights on the On/off touch button also functions as air quality indicator: blue, green, yellow, red (something like that)
VirusDoctor is Samsung's fancy name for ionizer function, default is OFF.
Just full blast all the way, can't hear a single thing
So for AX40 we can actually off the ionizer by pressing on the filter reset button? I was still searching high low for the button. How to know if the ionizer is off? For sharp, there is a specific ionizer button and when its off, the blue light goes off too. Does Samsung ax40 have something similar?
chuanz
Yes, there's light right above the VirusDoctor/Reset button. Btw, default is OFF.
keigo22
(Polluted) Red->Orange->Yellow->Green->Blue (Clean)
Pressing the ON/Off Switch
The air purifier turns on with a ringing sound.
-When the product turns on for the first time, it starts operating in air purification mode (airflow speed: Weak). ffIf the power [ ] is turned off and then on again, the product operates base on the last settings.
-The cleanness indicator and the selected function indicator are selected.
Pressing the Mode switch
Whenever this button is pressed, the mode changes in the following order: Weak  Sleep  Auto  Strong.
-The cleanness indicator remains the same and the selected operating mode is turned on.
-When the unit is running in Auto mode, the air is automatically kept clean by the air purifier regardless of the surrounding
dust and odors.
-If Sleep mode is selected, only the Sleep mode indicator is turned on (dimly).
If the filter clean/replacement indicator is turned on while the air purifier is operating, clean the Pre filter and press and hold the [ ] button for 3 seconds to reset the alarm.
If the filter clean/replacement indicator blinks while using the air purifier, replace the integrated HEPA/deodorization filter and hold the [ ] button for 3 seconds or longer to reset the alarm.
If the product is not going to be used for an extended period of time,put it into a box and store it in a dry,in door site.
ipaq4444
actually, SG air has never been good even on non-hazy days for past decade or so.
esp after 2013 terrible haze.
that's in my opinion lah.
i bought an air purifier in 2008. Used it for weeks and noticed indoor air greatly improved.
have decided on those non-ioniser or independent ioniser ones because read that mostly ozone is released during ionizing.
ax40 is consider as independent ioniser ?
Asakura
ok the ax40 manual (english) has been shared a couple of times in this thread.
so why is those people having problem with the controls/icons not downloaded it yet?
Dew36
In the past, I always thought hiding indoors and close all windows and doors I would be fine... Seems like not the case!
Definitely not the case. Even with Windows and door closed, a small AP will be struggling to keep the particle concentration in-check to below 30 ug/m3 when the outside is above 300ug/m3 on the handheld meter (not NEA). So think about that without an AP around....
Sent from Samsung GT-I9500 using GAGT
PholkLorr
SEMAIR10. valid till 30th sep
If you have ocbc credit cards, it will be more worthwhile to wait till tomorrow. Additional 13bucks off.
Total SGD 313.50
Shipping Fee SGD 0.00
Coupon -SGD 47.03
Payment Discount -SGD 13.32 (5% OFF)
Points Spent -300 Points
(300 Points = SGD 3.00)
Order Total
SGD 250.15
Thursday have OCBC card discount on Rakuten?
RalliFTO
Sharp is good... why u replacing it?
Been using the Sharp for a number of years and never changed the filter. Can't seem to find the filter anywhere at the moment so decided to get the Samsung since it is also an upgrade.
