Air purifier?
wizardundo
I've gotten myself a new cheap humidifier >~$30/- but it seems like cant work hand in hand with the AP. Every time I on the humidifier, the AP turns red even when I place them far apart (not really far, just one the other end of the room :o)
I'm wonder will it affect the AP in long run if it keeps absorbing the tiny mist produced by the humidifier. Currently running them on alternate days. :s12:
kawatsu
Anyone knows what is the specs for Sharp 28 filter if i want to custom order one from TB?
Dew36
Quoting from Bro WRX's old threads
Sharp A28 is this one. This is 300mm x 300mm x 25mm, no edge. Must DIY squeeze some tissue at the sides to act as gasket.
I have tested and measured before, it's operating at 95% efficiency at 0.3 microns. Pretty ok.
RMB29.90 each only. Buy 2 and get 5% off. Buy 5 and get 10% off. Free ship to your China forwarding warehouse.
¾Ü¾øSmartAir±©Àû hepa¹ýÂËÍø diy×ÔÖÆ °ì¹«ÊÒ¿ÕÆø¾»»¯Æ÷¼ÒÓÃÂËо-ÌÔ±¦Íø
Not sure about EP-A3000 size.
ALWW this seller and do custom. His filters are 97% efficient.
ÏÄÆÕ¾»»¯»ú¹ýÂËÍø×¨Òµ¶¨×ö(ÊʺÏFZ-180HFS/FZ-240HFS/FZ-A420HF)-ÌÔ±¦Íø
These filters do more than enough even for the usual Sensitive/Susceptible Group folks. What matters is really to close the door and windows properly (turn on aircon) and also select an air purifier that does at least 5 air changes per hour for your room. IF can do 8X, do it. The absolute filter efficiency makes very little difference in real life.....from my testing and measurements.
Dunno if he has newer lobang nowadays :D
WussRedXLi
New lobang is buy BNIB or near mint stuff from carousell / gumtree.
LG PS-R459 for $120 delivered. Midea KJ30NV for $100 delivered. All brand new in box.
But now is way too late.
NWT1978
gumbokins
Would it be counter productive to run the AP and light a scented candle at the same time? :s22:
WussRedXLi
I also ordered on 14 Sep evening, shipped 15th Sep and delivered this morning.
Naise....just in time.
s016
Which model is recommended if need by next week since the korean models will not be shipped so fast due to the holiday?
Thanks.
laeticia
I use an aroma diffuser I got from Muji, can smell the essential oil and it doesn't seem to interfere with the AP. It's not exactly a humidifier but it does produce a fine mist
laeticia
Was in my parents' room earlier and moved the Samsung AX40 over there for a couple of hours. The light sensor will change colours on and off (usu from blue to yellow or green),I wonder could it be due to the windows not being air tight? The light sensor doesn't really change when in my room unless I open the door.
