Air purifier?
Asakura
as usual. when numbers get high. more people go around asking where to buy ap. where to buy mask.
stam
vofzxy
i started a boh liao thread with a summary of all the AP info liao
should have less people here asking what model is good
joelhaw
Anyone could advise, the original ax40 filter, is there any expiry date? I intend to get another 1 as backup. Thanks.
mindgamey
Just go and customise a thicker version at 45mm. Or even 60mm (check if you can close the cover. Get 4pcs for cheaper price. You will need that extra 5mm, as the TB HEPA is a bit more restrictive.
Else, the model is Sharp FZ-280HFS.
RMB 77 only, from the AX40 customisation seller.
Will probably add 5-10RMB to the price only.
https://item.taobao.com/item.htm?spm=a312a.7700824.w4002-1526560714.26.EdAQtZ&id=16533394255
Correct dimension for my Sharp A50
WussRedXLi
anybody knows where still got physical stock.. ?
like none on the shelves everywhere.
1.5 months after PSI 100 hit and nearly 4 weeks of dense haze start, i think chances of getting a decent AP that is of value is slim.
gxelan
There sure still will be people asking, among the models which one is better, which one have stocks, where have stocks etc etc etc
Immortal
Hah.. yeah.. given up and ordered AX40 online.
In short, whats the benefit of a custom AX40 filter ? Thread is so long and i went through many pages but cant find it. :s11::s11::s11:
