Air purifier?
joelhaw
For mine, normally turns red when I on it (after letting fresh air in) and remain for about 5 mins or so.. afterwhich seldom turns back to red unless I toss my blanket or uses deodorant.
Mine when I turn on it stays on Blue. Probably my house has clean air? coz I closed the house door, left the kitchen windows open only. I put the AP in my room.
mindgamey
Can I just check, AX40 when I turned it on the Air Quality indicator remain Blue for about a min and doesn't change color. Does the AP takes awhile to change color when it detects bad air quality or it changes immediately? Thanks.
You need the air to circulate awhile.
Usually at high power if the air is dirty the change will in around 10 seconds
joelhaw
I testing the AP with door wide open, and place it abt 2.5m away from the opened door. The indicator remain blue in high speed mode. Means my air quality here so good? I turned it on for abt 2mins already.
laeticia
I am quite worried about this because it says SAMSUNG 'compatibility' Filter at the title page and there is one FAQ asking if it original went unanswered. I hope not 3rd party..
hmm yeah I see what you mean, I have cancelled my order to be on the safe side. this is what happens when you shop online in the wee hours of the morning :s22:
joelhaw
simple test - use ur mouth and breathe onto the sensor. it should detect bad air and turn red. serious this is what I did to test as I dont smoke
Hahaha! I did that! And the indicator turned red immediately! And now moving back to Blue within 20 Sec! Thanks.
PS : Think the air in my house very clean, that is why remain blue! Hahah
mindgamey
You testing it now?
The air today out is relatively good. I am not surprised it's ok.
My Xiaomi AP reporting 30 ug/m3 in my house right now.
On hazy days of AQI 150>, my AP report 50+ug/m3 (windows closed).
joelhaw
You testing it now?
Yup yup, just finished testing. Decided to turn off the AP today since the air is quite good! :)
Thanks all for the help!
mindgamey
I used a birthday candle, blow it out and it generates a lot of smoke.
linusz
Ha no I didn't. I assumed is all fixed up. So I need to remove the cover and take out filter plastic ah
Mind sound smooth. Almost can't hear anything even on the high mode. Did you remove the plastic wrapping of your HEPA before using?
whoooo
Quick resell to me nao....haze over , clean air Liao.....quick deal by 5pm :)
Wahhhhhhh u dint remove the HEPA filter packaging and turn ON the AP????......
joelhaw
Sorry not for sale! hahaha...
*touch wood, sekali the haze comes come tomorrow how?* :p
linusz
No lo my son keeps clamoring over it and presses the buttons. Until I had to lock it
joelhaw
Yes! haha... remove the back cover, cut open the wrapper and put back. There is only 1 way to put back the filter properly. Aftewhich, turn on! and TADA! hahahaha...
whoooo
Serious today is just temporary respite, it will be back as the fires still raging in Sumatra and Kalimantan
