Air purifier?
kcwlee
Do you guys use the power cable that comes with the AX40 or do you use a local purchased power cable?
I use the plug direct into our socket of those 3 way plug or multi socket adapter. The pin is slightly narrower than our 2 pin plug, with a bit of force it can fit. But don't try on your wall socket as the plastic is thicker (will damage ur wall socket housing or the plug might get stuck), those 3 way plug and multi socket ones are thinner and should fit.
Disclamer: At ur own risk ya...
The plug on the left is AX40,
laeticia
Just plug into a travel adaptor first and there's no risk of spoiling the plug
Initially had a couple of spares lying around the house but now running out :s13:
laeticia
what country's standards is the plug of the AX40 from?
Its a S. Korean 2 pin plug that's slightly thicker than our own local 2 pin, thats why cannot plug into socket.
Spore electronics brought over (if 2 pin) can be plugged in there although it will be a tad loose in their socket
hongge
Goni selling ax40 filter at $63. If use item discount -1 & cart discount -10 then use gift card -50, the total price only $52. Not yet taking into cc cashback of 6%. Is it gd price?
ralliart12
Btw, are we (recipients) allow to re-direct FedEx shipment (to another address) while the shipment is in transit?
makav31i
It is a good price...now trying to figure out how to get more $10 cart discount for above $50 spend...
autumni76
After comparing a few, i bought Samsung AX40 from Qoo10 by GoniGlobal.
My question is, after on purifier and i sniff at air outlet, my throat started itching. Could smell machinery smell and weird smell.
Why is this so? Worried it's doing more harm than good.
My windows and doors have been closed for weeks already and i was using my old Europace 82H prior to Samsung's arrival.
