Air purifier?
djork84
Goni selling ax40 filter at $63. If use item discount -1 & cart discount -10 then use gift card -50, the total price only $52. Not yet taking into cc cashback of 6%. Is it gd price?
as previously mentioned, this might not be the original filter. so take note.
makav31i
They just replied when someone asked if it is the original filter...
Hello, is this filter Samsung original or 3rd party? Thank you.
[Re] Samsung Original filter?
Dear customer
It is original Samsung filter
Thank you
Regards
meesoto
now then they informed u?
they want consumers to preorder first?
then they should have stated first...
Goni emailed me they oos for LG 390...ordered on 29 sept...
We should have seen this before ordering. This level of service is on par with the worst of the Chinese TB sellers. Now stuck in the middle of nowhere. :mad:
autumni76
I'll teach you guys how to save more with the AX40.
Every year, the haze months run for about 4 months. You can use 1 x original HEPA for 8 months hazy periods, so that's 2 years lifespan per original HEPA filter.
Non hazy period of 8 months, you can use this Taobao filter. Don't have to customise (so no need to type in Chinese to converse with the seller), just trim the part that runs along the pleat. Then the top part can just roll up the plastic packaging and plug the gap. It would work, trust me, I have measured.
Same, 4 months for the filter. So 1 year use 2pc.
RMB 29.90 per piece. Just buy 6 or 8 in 1 shot ba.
This would drop the airflow by about 35% max (it's more like 30% actually, actual measurement with my anemometer). So it becomes 210 m3/hr. It would also be slightly more silent, and suck less electricity due to slower motor rotation with the added resistance (as measured current draw with a multimeter). 210m3/hr is good for 14.5m2 room with 5 ACH, shd be just nice for MBR during non hazy months.
http://world.taobao.com/item/412171...&spm=a312a.7700824.w4004-8871129750.35.4ePHOj
This one I guess can use on normal fans too?
Saw something like "Smartair" at taobao. They use air circulator or powerful fans with filters.
Those who bought the AX40 from Happy Mall, your set comes with a 2 pin plug. Actually no need adaptor right? Those cheap plastic device that helps you plug into 3 pin outlet will do?
Tryg2015
After comparing a few, i bought Samsung AX40 from Qoo10 by GoniGlobal.
My question is, after on purifier and i sniff at air outlet, my throat started itching. Could smell machinery smell and weird smell.
Why is this so? Worried it's doing more harm than good.
My windows and doors have been closed for weeks already and i was using my old Europace 82H prior to Samsung's arrival.
Even with air con and AP you must air your rooms 2-3 times per day, to replace the stale air with fresh air. Otherwise there will be C02 buildup...
New AP filter will have a smell, I guess that's what you are referring to as the machinery smell. I notice that with both of my Samsung A40...
It will go away after you run it for a few hours. As for your itchy throat, I've not experienced it so can't comment, sorry
gravavva
No, you need that cheap adapter (Refer to the image a few posts back) because the plug is of slightly different size, so even with that plastic key it would not go in.
You can try to force the plug into the SG socket but I wouldn't recommend it, if you manage to force it in, the device will work because the voltages are right.
Tryg2015
Yes bro, just buy the cheap kind
But I prefer the bulkier kind from Japan home(see the photo one bro attached quite a few times, think it's bro asakura ?) easier to take out than the flimsy think type
derazor
Yes those multiple sockets , you can try to JAM or get converter.
The former if your house burn down don't find me
autumni76
thanks for the reply.
redsox
after I placed order with Goni, then only I saw that only Happy Mall put the sign "We sell authentic Samsung products only"
:s22:
I was about to place another order with Goni this morning with their $300 [Free Hepa Filter Event] timesale. But after I saw their $63 thread "SAMSUNG compatibility Filter", I choose not to get from Goni. If they are selling authentic filter, they should advertise as ORIGINAL instead of COMPATIBILITY.
makav31i
:s22:
I calculated, I can get the filter from Goni at $46...Buying from taobao is around $45+...Need someone to purchase it loh to compare...
makav31i
you still got the hepa filter in the box...can take picture so that i can compare with the filter i bought from daiso?
autumni76
sigh... mine from Goni. I bought with extra filter.
The filter came in a plastic bag. If there were any box before, it was removed. (But why removed)?
The pictures taken by Happy Mall buyers, the filters all got boxes.
and I'm still enduring the machinery / weird smell coming out from my Samsung AX40.
The air makes my throat itch as it does whenever the psi hits 300 and above.
And someone was complaining about Goni's VAV Hanebaro II air purifier, said they don't have the distributorship why are they even selling.
I really speechless liao. :(
redsox
So far have not bought any extra filters yet. My set with extra filter from Happy Mall is on the way. I will compare the filter in the unit and the extra one in the Samsung box to see if there is any difference.
Maybe those who got extra filter from Happy Mall can comment if the 2 filters are the same quality.
Tryg2015
Hi bro
Should you decide to sell your Samsung because it makes you uncomfortable, I think many here will be happy to take over from you at $200... Myself included
Hahaha
