WussRedXLi
- Jun 15, 2001
The filter used on the A50 is better?
Hence the same price.
Ok, it works this way.
A50 = True HEPA, 99.97% @ 0.3 microns...that's the worst performance particle size.
A80 (non humidifying) comes with H10/HEPA-10, 85% efficient @ 0.3 microns....worst performance particle size.
But A80 is what.... 480m^3/hr airflow. So times 85% is 408m^3/hr of clean air per hr.
A50 on paper is about 350m^3/h i think.
Improving it is easy, just get HEPA-13 from Amazon. Might need to get 2pcs to patch it up (scotch tape, soft PU foam to prevent bypass at the sides)....but trust me it's v much cheaper there. For my KC-840E, i can do it for 3X cheaper, at SGD35...using Honeywell H type H13 filters.
