Air purifier?
WussRedXLi
Anyone tried Panasonic FPXJ30AHS?
Are they quiet?
http://www.peshk.panasonic.hk/upload_files/P-AP001D1.pdf
I know what you are thinking, the prices of $199 and $299 for the 2 models that you commonly see in Best Denki and OG is quite tempting, coz it is Panasonic brand (nevermind the country of manufacturer). The airflow specs is decent for the price.
However, i can't seem to see any mention of the words "HEPA". Never mind if it's H10 or H13. They just say composite filter.
makav31i
Anyone can explain how the voltage system work if I were to buy air purifier from Amazon...
clementiboy
Hope this helps!
Power Up Singapore
Electricity in the US
Voltage
The United States uses 110-volt electricity, whereas most countries outside North America use 220-volt electricity. Unless your electronic device has dual voltage capability, you need to use a converter or a transformer to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt device overseas. If your appliance is dual voltage, you can switch it to work on 220 volts without a transformer or converter. You can check to see if your device is dual voltage by looking at the electrical information on the body of the device. If the symbol 110/220 is present, it has dual voltage capabilities.
Electricity in Singapore is 230 Volts, alternating at 50 cycles per second. If you travel to Singapore with a device that does not accept 230 Volts at 50 Hertz, you will need a voltage converter.
WussRedXLi
Robinsons selling at 299 for Novita 501 but with free Speedpost delivery. I got it at 278 that time coz 7% off. Robinson private sale 10% off with free speedpost delivery.
Others like BD, HN needs $30 delivery.
InnovaIQ
I enquired at GAB for the NAP611, they said it does. So I suppose it's the same for 501.
bro.................knn..................u haf how mani....................air puyrifer??????????????????/** so mani...........................which 1 2 hoot????????????????????????moi confuse....
Zabiyaki
Go amazon buy new keyboard first:s13:
InnovaIQ
bro....................buay swee leh............................moi lealli...........wan 2 ..................get 1 purifier wat................mai suan siao moi leh..................
WussRedXLi
Now I have 3. :s22:
1 x Sharp KC-840E
1 x Novita NAP501
1 x Samsung AX40
You have to decide for yourself and stick to your budget lah.
InnovaIQ
Now I have 3. :s22:
1 x Sharp KC-840E
1 x Novita NAP501
1 x Samsung AX40
bro..............wich 1 best??????????????????wich 1 no jiak electricity ??????????????????moi wan .................cheap n goot 1........................
chuanz
Ur posts are really.... atrocious to read. Into my ignore list rah!
InnovaIQ
moi..............................2day................go BD.................saw samsuck...........sellin............ax41..............same model as ..................ax40????????????????????????
serangoon1
If just put in my masterbedroom
is it better to get novita nap501 or novita
nap 611?
Zabiyaki
nap 611?
See the size of ur room..if ur room dam big get the better more ex one..if small than not so impt
The more ex models have better airflow thus filter more air
If ur room super small u get the best model also same performance as the cheaper ones
