Akai Ryu
- Dec 14, 2007
Use in singapore la. Any idea forwarder charge how much for shipping 4pcs?
They really like to measure SPL at the outlet of the AP instead of @ 1m like the others eh?
采用阿波罗(APOLLO)高密度PP和PET材质HEPA滤网
净美仕8088A采用了日本阿波罗滤网
展开面积为0.35平米,比小米空气净化器0.18平米大了近一倍,
Samsung AX40 = 0.0868 m2 filter size area.
Mfresh is 4X bigger. Depth is still unknown. Just absolute numbers. This affects air velocity over filter media. Anyway, don't think too much.
Just get from the highest number of sales. ALWW got 现货吗? And use 顺丰, don't think too much. 2 of my chairs shipment using yuantong and zhongtong (supposedly ok) I see the box I also shake head.
Advantages and disadvantages:
Advantages
1: CADR high speed to the fastest indoor air purification
2: the same maximum power and sleep mode noise control is very good
3: Simple cleaner user interface, easy to use
4: Indoor air PM2.5 numerical value the fact that the form is displayed on the screen purifier
5: Comprehensive data calculation filter life, delay life and reduce unnecessary waste
6: Expand the filter area, the use of coconut shell carbon as a last line of defense
7: Mobile APP side to provide a friendly user interface , supports remote control and a variety of automatic operation mode
8: Mobile APP end real-time display purifier where air quality, humidity, temperature and record a chart showing
9: cleaner even after the network can rely on the nearest station data adjustment purification running state
10: Live View filter to estimate the remaining life of usage and
11: internal work no obvious design flaws, especially in the wind tunnel, the motor, fan blades solid materials. Can foresee a very long service life
Disadvantages
1: Although a total of seven hours after use coconut shell carbon sour disappeared, but within the first two hours that the acid is really cool to teach people a new life every minute
2: Although the standby power consumption Other smart devices equivalent or better than conventional cleaners save
3: Expand the area although there are millet filter purifier 2 times, but the price is more expensive than millet cartridge Summary: materials, workmanship worthy of its price. Priced at 200 yuan a filter, post-use costs are not too high. In addition to millet purifier thousand dollars a choice
always do these 3 steps when buying from taobao.
take the plunge and hope for the best.
highest sale
alww for stock
use shunfeng
Here's another car air purifier S$199
http://estore.novita.com.sg/products/air-purification/aircaretm-car-sterilizer-nas-c-1000.html
This should be the most feature packed vs Philips or Mann.
CADR is lower
10 m3/ hr | 16 m3/ hr
But it has ozone and ion generation
best air purifier i seen in singapore so far!
1) able to filter as small as 0.009micro which exceeds the HEPA filter criteria (0.3micro)
2) able to clean an HDB room size with Turbo mode on in 30mins, which cost only $0.09 (assuming operating at 8hrs)
3) comes with a guarantee of 3years
family with elderly, babies or pets will be able to feel the difference in the quality of air the most.
well, i must admit it's cost is high which is fixed but the variable cost(cost of using and price of filter) will be the most concerned in my point of view
feel free to PM me for more information, i will be most willing to share more about it =D
If it's the Amway Atmosphere, it's good, but for a similar price the IQAir is better. Both are really overpriced anyway. Benefits over the IQAir are size and service (since you'll probably be buying the Amway from a friend...). The Amway is about half the size of the IQAir and quieter.
I think someone was asking if the Balmuda and Xiaomi filters are interchangeable. They are not. The Xiaomi filter is bigger and will not fit in the Balmuda.
compare to GoPure Phillips dunno which one good....
