Air purifier?
Akai Ryu
any sharp AP users using? I just dump silver block into my water tank. Rast time dump bamboo charcoal in
img.php
Akai Ryu
oolong advocated by Sharp wor https://youtu.be/lXs_vnfEcI8?t=271 :s13: will try check my manual and try try when i wanna change my deodorizer
:s13::s13:
・ ニオイがとれにくい場合は、ウーロン茶に10分程度つけ置き洗いし、十分にすすいでください。
If the smell is difficult to take is to wash soak for about 10 minutes to oolong tea, please rinse thoroughly.
http://www.sharp.co.jp/support/advice/air_purifier/care_kc_d03.html
WussRedXLi
Bought the MFRESH M8088A. 717 x 330mm dia. 9kg shipping weight, 5.8kg product weight. Box shd be ok. 70W. 580 m3/hr CADR. 58dBA so it's somewhat loud. Reviews are ok.
Not really good value for money, I think SGD300 reach SG everything in, so still below GST . (not that 4PX would need to pay GST anyway, if you know what I mean, never had to even though I made "mistake" twice)
I upgraded to 顺丰。 9kg shipping. Below 10kg. Ship from BJ.
I bought chairs before, 15kg. 圆通crushed the box and the wooden legs were broken, used Selley's liquid nails to patch, luckily ok. But internals got no styro then.
This one has styro. Added RMB80 for 顺丰。 (still no air, use land).
Hope for the best.
Reach SG, the Speedpost uncle is pretty ok. Trolley etc. No failures before with iherb, Amazon iparcel, 4PX. Many deliveries before.
Akai Ryu
Hope for the best.
have u found replacement filter for this ap??? :o
vofzxy
Ok, Sharp A28 filter dimensions are 285mm x 310mm x 25mm. 1 inch thick filter
So the above Amazon H13 filter can fit. Slice up the 330mm to become 310mm (very easy coz the pleating is in the same direction) with a penknife. Scotch tape....the seal will be good.
285mm, need to use a strip of PU or LDPE foam and UHU glue to stick and cover the 5mm gap.
for future updates
WussRedXLi
RMB 199 from TB. MFRESH, so will have support, no worries. It's a huge filter. Biggest that I have ever seen. ...bar the IQAir.
I think I will sell the LG LA-Q379SB now. Fast hand fast leg. Too many APs.
232-155mm = 77mm. Of coz it's not truly 77m thick when stretched our horizontally, but close. Maybe 70mm? That's H11+AC
linusz
What's good about this monster.
232-155mm = 77mm. Of coz it's not truly 77m thick when stretched our horizontally, but close. Maybe 65mm?
Akai Ryu
WTF IS THIS SORCERY?!:eek:
Is that the activated charcoal filter? Means oolong cha can remove odors?
based on this beedeo https://youtu.be/5XCjUy4AoK4 the Sharp deodorizer filter is actually not activated charcoal as what we expected.
Its actually 冷触煤 Cold catalyst, similar to Novita's
Cool Catalyst Filter : By producing reactive oxidants to oxidize; breaking down the contaminants into carbon dioxide and water molecules to eliminate airborne germs and VOCs (Volatile Organic Compounds)
https://0dbd90cfe234c84972114215f54...HlhTHV5UWV4UlU/Novita/NAP611i-feature-001.jpg
Cold catalyst
  Cold catalyst , also known as natural catalyst, following the photocatalyst deodorizing air purification material after a new type of air purification materials, under normal temperature conditions can play a catalytic reaction , so that a variety of harmful odorous gas at normal temperature and pressure decompose into harmless tasteless substance , from simple physical adsorption for the transformation of the chemical adsorption, the adsorption side edge decomposition, eliminate formaldehyde , benzene, di toluene , toluene, TVOC and other harmful gases, water and generate two oxidation of carbon in the catalytic reaction process, cold catalyst itself not directly involved in the reaction, the reaction does not change the cold catalyst is not lost, long-term role to play. Cold catalyst itself is non-toxic , non -corrosive , does not burn, the reaction product of water and carbon dioxide, does not produce secondary pollution , greatly extending the adsorbent material using life .
  Main purpose : cold catalyst mainly used for air conditioners, home air purifiers, car air purifiers and other purification devices, can be used to deal with man-made sheet, furniture, wall wallpaper, carpeting, curtains, bedspreads and indoor air free of formaldehyde, ammonia , TVOC, hydrogen sulfide and other harmful gases.
  Cold catalyst, also known as low-temperature catalysts, formaldehyde nemesis . It is for the formaldehyde has strong scavenging ability.
  Principle Cold catalytic oxidation catalyst, catalyst components that play a role in the process medium, its composition does not change, can be long-term use without any treatment. Catalytic decomposition reaction does not require ultraviolet light , high temperature and high pressure . When the temperature reaches above 5 ℃, humidity at 40% or more of the conditions, cold catalyst catalytic decomposition of harmful gases effect can be achieved ideal state.
  Cold catalyst is a high-tech catalyst that not only catalyzes the formaldehyde in the air oxygen reacts, but also catalytic ammonia, toluene, xylene, hydrogen sulfide and TVOC in a variety of harmful gases react with oxygen to form water and carbon dioxide. In the catalytic reaction process, cold catalyst product itself is not directly involved in the reaction, after the reaction was cooled catalyst does not change is not lost. Therefore, once employed in the absence of external damage, the validity period of up to more than eight years. Cold catalyst main components are food , pharmaceutical additives, non-toxic, non-corrosive, non-flammable. The reaction product of water and carbon dioxide, and no secondary pollution. Is future-oriented, the most suitable for home health security, environmental protection products.
http://www.uuuwell.com/mytag.php?id=50122
