Air purifier?
WussRedXLi
Seriously, if the wind starts to shift for whatever reason, I really don't know what will happen.
Right now still a lot of happy people walking at Orchard, in the streets etc. We are still lucky.
blues7
On the west, everyday by later afternoon, burnt smell very strong, need to close all windows
This is already very uncomfortable
And it will last the whole night until next day morning
In fact, burnt smell all day, just that stronger smell for 12 hours or so
And yes, aware that situation can get a lot worse
World's most expensive city
We can reuse waste water, can we create rain?
slurpy0099
bought juz before cny, lelong nobody buy tat time at harvey norman~
Is this true hepa?
WussRedXLi
Is this true hepa?
Did a search. Apparently it's one of those HEPA type purifiers. Maybe can do 2.0 microns high-efficiency (check out Amazon, lots of them) but suspect 0.3 microns is not that good. More for pollen/dust.
https://sharp.com.sg/web/products/prodDetail.asp?ProdId=325
See FU-A28 (mosmos also have, I remember). That one is H10/E10, or "HEPA-10" if you will, 85% @ 0.3 microns MPPS/most penetrating particle size definitely close to 100% at PM2.5/2.5 microns.
WussRedXLi
HEPA class
retention (total)
retention (local)
E10 > 85% ---
E11 > 95% ---
E12 > 99.5% ---
H13 > 99.95% > 99.75%
H14 > 99.995% > 99.975%
U15 > 99.9995% > 99.9975%
U16 > 99.99995% > 99.99975%
U17 > 99.999995% > 99.9999%
HEPA filters, as defined by the DOE standard adopted by most American industries, remove at least 99.97% of airborne particles 0.3 micrometers (µm) in diameter. The filter's minimal resistance to airflow, or pressure drop, is usually specified around 300 Pa at its nominal flow rate.
The specification usually used in the European Union is the European Norm EN 1822:2009. It defines several classes of HEPA filters by their retention at the given most penetrating particle size (MPPS):
HEPA - Wikipedia, the free encyclopedia
So can take it that your N95 is E11, and N100/P100 masks are HEPA-13.
nivek999
Depends on the setting.
My plan is one unit per room so $199x4 is less then $800 so still reasonable. Right now the psi is still okay okay so will leave at low first. Worst psi case scenario is put all the units at full power into main hall and whole family sleep there.
so extreme meh?
reds79
i have NAP 301.
Seems like this model no longer available in the market.
So what's the difference between NAP 301 vs 501?
no idea....
current unit is from samsung.....
buying one more is for wifey who is pregnant and due in june
in case i need, like last year everywhere OOS....
alamin2
bought the taiyo air purifier during IT show. not bad.
ive a philips air purifier also.. and a bionaire.
dont get bionaire... super freaking noisy.....
WussRedXLi
Thanks, will give it a try
No prob, hope that helps!
If really OOS, just get the 3M Filtrete air con filter from HomeFix or NTUC. Then on the a/c nearly 24 by 7. If afraid of $$$ then set temp at 26 or even 27. Seriously, with a HEPA air purifier you are supposed to use it in an air con env.
The pm2.5 confirm will drop decently. PM10 no need to say, pretty effective. Tested here in EDMW by some bro with an air particle counter.
procmail
HEPA class
retention (total)
retention (local)
E10 > 85% ---
E11 > 95% ---
E12 > 99.5% ---
Interesting, thanks!
So those Sharp, Honeywell (HA170) are under which class?
WussRedXLi
Sharp ranges leh.... the more ex models are HEPA-13. Stuff like A28 is E10. Then also got the recently mentioned Z30 as dust collection bag. But got a model that's Z31 that's E10.
Honeywell basically HEPA-13. But they also got desktop models (ie Amazon got quite a few) that are like N95s. 95% @ 0.3 microns.
http://www.amazon.com/Honeywell-Com...640140&sr=8-4&keywords=honeywell+air+purifier
There are also "dust collection bag type", ie 2 microns. They are effective for pollen and dust though, and yeah there are ok for hay fever/allergic rhinitis sufferers who would find such entry level model useful and very cost effective.
Eg http://www.amazon.com/Holmes-HAP242...394640230&sr=8-2&keywords=Holmes+air+purifier
ie for comparison's sake, a typical and cheap vacuum cleaner bag made of PAPER can do > 99% efficiency @ 3 microns. (note : HEPA is 0.3 microns)
Not everyone needs and have 3k budget for IQAir 250.
procmail
Amazon.com - Honeywell Compact Air Purifier with Permanent HEPA Filter, HHT-011 -
Eg Amazon.com - Holmes HAP242-UC HEPA Type Desktop Air Purifier - Hepa Filter Air Purifiers
Thanks.
So I think my old Sharp FU-21SE-S is probably E10, and my Honeywell HA170 is probably HEPA-13.
EDIT: hmmmm the manual says FU-21SE-S is a True Hepa, whatever that means.
mosmos
High Honorary Member
tis foto ish at Jem ntuc in Jan 2014, not sure got stocks anot~
