Air purifier?
Hisashiburi
Only the expensive ones are left.
Cheaper versions all gone from stores.
Saw some Philips/Delonghi/Novita at CKTang and Robinsons
mosmos
High Honorary Member
blues7
i'm going for novita 501 with filter $299
a few years ago bought OSIM iLIfe air filter for many hundreds of dollars
it was ok but now can no longer get filter becoz osim no longer produce that model
wasted money on the machine and filter was not cheap. need 2 types of filter and together can cost $100++
a few posts ago, someone mention sharp iar filter good and can still get filter even when they no longer make old models
well, that's good too
WussRedXLi
switch on aircon liao... y u all still need purifier?
The stock air con filter probably can't even filter 500 microns.
Those aircons with built in cleaning helps a bit. But their performance won't even come close to the smallest/cheapest HEPA unit (eg Sharp A28, $128). Maybe 5%?
WussRedXLi
Yep...for the Sharp models, they usually stick to the same sizes. I am using the latest model filter for my old one.
In fact my old one, the A40, is actually "HEPA-10", or E10...85% efficiency @ 0.3 microns, or say the air CFM is 200 cuft/min then the clean air delivery is 0.85 * 200 = 170. Same as a True HEPA with airflow at 170 CFM @ 99.97% efficiency @ 0.3 microns. So I use the latest one which is actually HEPA-13, or True HEPA. Automatic upgrade. :s13:
blues7
anybody know where to get replacement filter for philips AC4025 air filter?
NWT1978
that good to hear...easy for us to buy filter
was thinking of which one to get... seem Sharp a better brand model.
WussRedXLi
Not to say better lah, but it's one of the brands to get definitely. I got my Sharp 840E (predecessor of the Sharp A40)at just 429 that time. Depends on the offer.
I think mosmos got his Sharp A28E at 79 dollars only, Courts offer last year. I nearly wanted to get that at $128 also last year, BEST Denki offer. Now is 169. That one is E10/HEPA-10. More than good enough for the small 4.x by 3.x new HDB rooms.
Worst case scenario if Best Denki closes down, filters still can get from ebay. Sharp is used worldwide.
reds79
Will do a pre order once reach office....
