Dey, you should also edit out the advertising link / Facebook when you quote if you're so against itmod is this considered advertising?
Lololol you really think he is aiming at the advertising post this time round?Dey, you should also edit out the advertising link / Facebook when you quote if you're so against it![]()
our weather for battery cannot last long.... heat is shorting the life span of battery unless u relocate ur batt to the boot....please no one buy energiser. $180 battery and after 16 months DEAD! spoke to battery shop and they said they dont sell any more because it to many problems. Spoke to Chin Send Hin and they said my fault because i only drive 5000Km a year. a battery should last 4 years. My Varta lasted 5 years. all the battery sellors here say a a battery lasts 12 months to 24 months but that is just rubbish as in USA they give 5 year warranty. Just a way to sell more. Buyer beware. can charge your flashlight but no good for battery
My Amaron 2yrs die liao. Jumpstarted twice. Now cant even jump start.
Worst den my wet battery which lasted 4years!
Depends on your driving habits.
Mine can last at least 3~4 yrs
Sent from Samsung SM-N9200 using GAGT
Long holidays need to disconnect the batteryMy amaron 13 months nia .. can't back from my 9days holiday cannot start liao. All the lights and camera were off before I left for holiday.
13 mths is either you got a lemon or
1. Your aircon is always turn ON.
2. Your HiFi is always turn ON.
And you always start engine with the above turned on.
!My amaron 13 months nia .. can't back from my 9days holiday cannot start liao. All the lights and camera were off before I left for holiday.
I'm currently using Amaron din 55.. lasted me for 5 years now.. I think it's due for change.. must I get the same din 55 or I can get other series from Amaron? The current price for din 55 is $200
Amaron batteries are made in india. Bosch batteries are made in korea. Bosch is a german company and they make the starter motor and alternator components for most big automotive companies. The positive and negative terminals of amaron batteries rust over time, unlike bosch batteries. Even the hard polyethylene casing for bosch batteries are of better quality.
Amaron pro batteries do not have a vent tube on both ends. It was not designed with mercedes, bmw, jaguar, lamborghini and european cars in mind. These cars got a vent tube which has to be left disconnected if you use amaron.
I suggest not to waste your hard earned money on amaron, globatt, motolite or even oem toyota batteries from borneo. Not that bosch never fails, just that it is either same price or $10-20 more than amaron.
I have taken apart amaron batteries and was surprised at its cheap design. I only play with brands such as fiamm, bosch, varta for cars. For lorries, incoe is excellent quality for money. For motorcycles, i swear by yuasa only, even for a bmw bike.
