Android TV Box
y2j
is it possible to install apks from unknown sources on the 1st gen Starhub Go boxes?
kkcheng77
Hi, what would be a good replacement for WDTV live nowadays? Has been using since 2013. Have a 1TB usb HDD connected and plan to keep using it. Also looking at possibility of using new setup to watch Kdrama. Any suggestions?
gregory_choo
currently any sub $15 box can do better than your wdtv :) :)
suggest to get "minix T5" or "mibox s"
NCMK
Hi guys, need some advice. Need to get an android box. Was deciding between mecool S905x4 based android or chromecast 2020. Which one will be the better one?
It will depend on your needs. If you need Netflix 4K, then you have to go with Chromecast 2020.
Mecool KM6 review: you will be lucky to get Netflix HD working with hacks. Disney+ will be an issue as well.
https://androidpctv.com/review-mecool-km6-deluxe-opinion/
