Anybody using Singtel Mesh?
renfred89
Thanks.
Need your advice. I'm thinking of either getting Singtel Mesh or normal 1gbps and using another router as AP in masterbed room. Please correct me if i'm wrong as i quite noob (Sorry :(
So for singtel mesh setup.
Router/modem place it in the DB Box (Off Wireless, use as switch).
1.LAN Connect the router to mesh 1 in the living room.
2.LAN Connect the router to mesh 2 in the masterbed room
OR
1. LAN connect Router as AP in living room
2. LAN Connect ROuter as AP in masterbed room
first setup will be better in view of single SSID and roaming ability..
guanguan
Thank you so much.
so now.
m1 Linksys Velop VS Singtel Mesh? Any experience in both?
Currently register interest in singtel 1gbps with mesh that comes with free 8 months, quite attractive
renfred89
Had used airties mesh before and now using velop. I personally prefer velop cos of the higher speed and system reliability.
That being said, the current airties mesh could have improved over the months and that both airties and velop could be similar in performance and features too..
Thank you so much.
so now.
ah_cleo
Ditch the airties and using samsung connect now.. so far so good except samsung connect is 2x2..
If can, i would use airties if not for my smart home stuff.
That being said, anyone wanna buy? Else it's an white elephant sitting at home. Lol
oneofthem
Interested in learning how the airties mesh works with Singtel TV, tried looking for documentation but can't find any. Any kind soul can help explain a bit?
Currently on SH cable in a 2 storey house. Just signed up for Singtel fibre and thinking of installing FTP on 2nd floor for wired LAN to PC and that's where my family has most of our wifi devices. Rather than routing a cable all the way from 2nd floor to ground floor for our TV, how can I set up a mesh for TV downstairs? Thanks in advance :D
ah_cleo
depending if they give u ONT or ONR.
if ONT
TP -> ONT -> Singtel Router.
behind Singtel router got 4 lan port.
-> connect to pc 1
-> connect to Mesh 1
-> connect to mio tv
-> connect to any other device u need.
mesh 2(can connect via cable to Singtel router, can dun need) - connect to another pc.
simple as that.
after which logged onto the default gateway of 192.168.1.254 for your Singtel router to disable wifi. use the wifi from the mesh
this is my house setup as i using ONT instead of ONR.
subzeroes
How do I get the lqtest firmware updates? Last time got my uodates from one Singtel account in here...
Kim
stephenbishop
Help!
Hi,
Hope the experts in this forum are able to help.
I have a large area to cover and am using 2 pairs of air ties mesh units together with a wireless router (Asus AC68) and 2 other wireless access points (older Asus routers re-purposed as wireless access points) - all using the same SSID.
I set up the first airties unit with a lan connection and get very good wireless speed on this unit. However, I cannot get an Internet connection if I connect any of the other 3 air ties units to the lan. I only get an Internet connection on these other 3 units via the wlan and the speeds are much lower than on the first unit.
Is there some way I can connect the other 3 air ties units via the lan and get similar wireless speeds as on the first air ties unit?
Appreciate any assistance you can provide.
renfred89
Your post is a little confusing.
You’re trying to set up the airties on wireless backhaul or wired backhaul?
Hi,
stephenbishop
Actually, I am a bit of a novice and do not know exactly the meaning of backhaul! If it is what I think it means, I am trying to set up airties on wired backhaul i.e. connect airties unit to a lan socket in a room (connected via a switch to the router in the DB room). Does that make more sense? Sorry if I am confusing you.
renfred89
First of all, you need to run the firmware that supports ap mode. You can download the airties app from your smartphone and if your firmware supports; it will show up on the app. If it doesn’t, you’ll have to ask singtel to push it down for you.
Otherwise; only the first parent node is supported via lan. The rest of the nodes will only be on wireless backhaul..
stephenbishop
Many thanks Renfred89. I think that is the problem. I downloaded the Android App "AirTies WiFi" and it says I am connected to the Guest Network and the app cannot be used in Guest Network! How do I get Singtel to push down the firmware which supports the wired backhaul to me?
renfred89
stephenbishop
I called 1688. The guy I spoke with said that wired back haul is possible only for the master node and that if I have 2 pairs of airties it means that I can have wired back haul for a maximum of two masters if I set it up as 2 masters with a slave each! Does that make any sense? It did not to me.
Anyways, he said that he will check again and call me back!
renfred89
If you scroll a few pages back, there was a newer firmware which enables ap mode.
What the person said isn’t wrong, just perhaps singtel has decided not to distribute the ap mode enabled firmware to their discretion, maybe it’s unstable or what.
In the mean time, drop singtel HWZ account a message and see if they can help you?
stephenbishop
I sent the Singtel guy on this thread a PM yesterday. Not heard from him yet.
The Sintel 1688 guy called me back and said the wired to wireless AP mode should be possible for all the nodes and could not figure out why it does not seem to be working for me. Arranged for a technician to do an onsite inspection tomorrow. Will see how it goes and I will report back!
renfred89
Check the firmware version?
People had posted the firmware version that supports ap mode a few pages behind..
