Ask Yamaha / FAQ
Infested_fred
Hi!
You can purchase a RF Cable with the connector like below:
from any electrical shops in Sim Lim Square or retailers like Best Denki, Courts or Harvey Norman.
Some HDB areas have small electrical shops may have it too.
Using this RF Cable to connect to your Starhub Box will achieve better Radio reception for your RXV465.
Let us know if you need further assistance.
Cheers!
Bro, using the RF cable connect to Starhub Box, means the one we connect our SCV hubstation outlet? The one on wall outlet? What if I don have the SCV box in my room? Any alternative?
YamahaSG
Featured Sponsor for Home Theatre & Audiophiles
Do you have the one on wall outlet?
YamahaSG
Hi Beemer75,
Currently there's no plan to bring this model in. And we are not able to do special order on this.
Sorry about it bro.
YamahaSG
sadly there wont be any mcr-140 - like the DAB.
how much is the TSX-140? Wld there be a National Day Promotion for this model (u mentioned a ND Promo for some other products)
tks.
Hi!
TSX-140 is retailing at $639.
Yeap. NDP Promo are our Digital Sound Projector YSP-2200.
See http://deluxeforums.hardwarezone.com.sg/showthread.php?t=3267506
Sorry that TSX-140 is not in the promo list for NDP Promo. But certainly we will consider something in such category for future.
Cheers!
chomechome
I am considering this model Rx-V571 and RX-V471.
I noticed that only RX-V571 can support HDMI upscaling, what does this mean? Do i need this feature if my blueray player already support upscaling?
YamahaSG
Hi!
RX-V571 supports upscaling is more use in Standard Definition sources like DVDs, VCDs, even SD Set-Top Boxes.
Hence it depends on your sources more for you to decide which model should you take on.
In future to come, High-Def will be widely available and Upscaling might not be useful. That depends alot on how long Singapore takes to move into Full HD broadcasting and also when can Blu-ray disc fully take-over DVDs. Also depending on your sources, if BD and Set-Top Box is all you have, you just need to upgrade your set-top box to HD one, and all you need is just RXV471.
Hope you get better understanding from here to make a decision.
Cheers!
chomechome
Hi!
Cheers!
I dont have set top box, i only have a blue ray player that supports upscaling. That means dont need the upscaling feature in RX-V571?
Thanks
mumbaki
Hi all,
I have htr 6230. With the dtv/cbl connection for my Xbox 360 with hdmi cable and optical cable, audio and video is routed only in hdmi.
If i connect my hdmi directly to my tv and optical cable to my receiver, this setup works.
Is there any way I can force my receiver to use optical link for audio and hdmi for video using the dtv/cbl connection?
Thanks..
YamahaSG
Hi all,
Thanks..
Hi!
You can't force it bro.
Do give a check over your Xbox 360 HDMI Audio Settings. Set the HDMI Audio to OFF and try.
Afterwhich if it still doesn't work, see below:
Let us know if you could get it work again.
Cheers!
YamahaSG
Hi,
I stay at the west side, where can i get the TSX-140? Thanks.
Hi!
You can visit Best Denki at IMM or Courts at Causeway Point to purchase.
Do you have any specific colour that you prefer? So i can divert you to the store that has ready stock for you.
Cheers!
archtomato
Hi!
Cheers!
Looking for gray and how much is it retailing for? thanks
boxster
Yamaha YSP-2200 with Starhub Hubstation HD?
Hi all, just got my Yamaha YSP-2200 yesterday evening, and all was good till I connected the Hubstation HD to it. My setup is Sony KDL40EX520 connected to YSP via ARC, BD player to hdmi1 for YSP, Hubstation HD to hdmi2. When I watch BD via hdmi1, all is good. However, when I switch to hdmi2, I see blue screen flashing. When I power off the Hubstation, and power it back again, the images come in. This morning, when I wake up to try again (all machines were on standby mode), the blue screen happened again! I had to once again power cycle the Hubstation to let images appear. Anyone has faced similar problem? Do note that I had swap cables and connected the Hubstation directly to the tv, and it works. Any suggestions would be welcomed!
Thanks in advance!
boxster
I paid $1490 from Parisilk with the iPod dock. But any help to my problem is appreciated
neon82
boxster
One more question, I tried to find the user manual from the Yamaha SG website, but cannot find the manual for YSP-2200, anyone knows where I can download it? I tried the US website, but needs to register to a US address before I can download it :(
