ASUS R9 290 @ $428???
hengheng220
i had google already...
What i meant is the R9 290 worth to get instead of getting at GTX760, since the pricing is not tat great :vijayadmin:
ah... if thats the question should have phrase it liddat ma lols misunderstood psps. back to the topic, depend on how much you willing to fork out and what how much do you mean by worth. IMO its not worth if you don't need its performance. Anyway here are the variants:
Asus ref card 290~ $428(Higher core temp and quite noisy but cheapest)
Sapphire 290 ~ $499 (Good non ref cooler, but 2 years warranty)
Powercolor 290 ~$499 ( Not bad non ref cooler, but slightly thicker iirc and 3 years warranty, one of the best priced 290 as of today)
MSI 290 ~ $529 (Good non ref cooler, slightly lower temp and quiet, lots of free gifts, but is on the slightly premium price)
Average 760 cost~ $320~$400
If i were you, i will take the 760 if i'm a light gamer running on 1080p monitor and will only pay for the 290 premium for heavy gaming usage. As for myself, I game at 1200p but regretted hooting the 290 as I seldom game after i gotten my rig. So in conclusion its up to your usage and your own preference.
Quest
I am looking LeadTek GTX760 @338 than i saw this promo R9290 @428.:eek:
So i was thinking the R9290 should be able to last longer than the GTX760 (in terms of running future game) right?? :vijayadmin:the diff is abt 90bucks...
I really dun wish to pay 500bucks for a gfx leh...heartpain :o:o
KingJio
Depends also on what settings u wanna game at. 760 can play future games at 1080p but maybe not ultra settings. I'd personally recommend r9 290 for futureproofing, but of course if u intend to upgrade your gfx card yearly then it's a different story.
hengheng220
That's will be hard to say, seeing that watchdogs so unoptimised for pc even 290 have problem running it. And also the game was developed in partnership with nvidia, the performance of the 290 in the game does not justify its true power.But that's just one game out of the many game released on pc. Yes 290 can last slightly longer than 760, but are you ok with the noise level and heat of a 290 ma? If you are ok then just go ahead ba just don't look back can le lols. I bought my 290 for 640 iirc.
ragnarok95
Senior Moderator
Senior Moderator
I had a 9800XT running over a yr @ 90+ degree during gaming. Anyone still remember this card??? One of radeon hottest monster.
Get the 290 over 760.
Quest
Since u own a 290, have u encounter overheating of the gfx??
My old desktop has a 4870, there was a few times when i was playing diablo 3 which my 4780 overheat & screen just went dark....:s22::s22: and i can smell burn or something:s13:
Have to let it cool down for a while then i dare to power on again:o
hengheng220
Nope so far no leh cause I'm a light user only occassionaly game. But even in crysis 3 max settings all still fine
shadow84
By the time u ask finish, stocks OOS le... left 4 more days till promo is gone.
viktOzzz
Yeah man. I remembered it was out of my budget, due to my Northwood 3.0C rig, thus, settled for the pro version, which is a AIB card that somehow, can be unlocked or clocked to near the XT performance. Of which, I only got the balls to do it after I got my artic cooler hsf for it.
ragnarok95
Senior Moderator
Senior Moderator
After using that card... what is HOT and NOISY??????
290 noise and heat is small cake. :s13: :D
ragnarok95
Senior Moderator
Senior Moderator
4xx is temping le.... but i only game L4D2 @ 1440p... even thought i cant max all the settings on my GTX670...but still temping...
hengheng220
hahahaha l4D get so high end abit wasted hor... I think the problem with L4d is more of the internet connection than gpu problem... Everytime i join game my ping is like :s22::s22::s22::s22:
cenedra
L4D2 very low GPU load leh. Im using 1440p as well, and L4D2 cant even max load my 7850 even with the highest settings
U can buy a 2nd hand 7850 for less than $150
To those who said 290 is noisy, I wonder if they have used it before.... I used to have 4 of them for mining LTC...
Its not noisy at all. The problem is actually with throttling, not noise.
royfrosty
Ifs a ref blower. And yes it is hot and is not quiet at all.
