Aztech DSL7002GRV-(s)
SuperSuf
I wonder anyone has this problem.
I have connected 2 NAS to the routr.
My laptop connected with LAN and it work properly.
But it doesn't work 100% when I connected with wireless.
It can connect, last the file and folders but cannot copy or upload the file.
Same issue here. Any resolution?
Thinking of going back to the Pace
reyreina
cross-posted in the DSL7000 thread, any experts here can comment about this?
called ST to request for a change to a Dual Band router (was given the DSL7000 recently when I signed up for Fibre) but was told that the 7000 is the best router they have available. When asked about the 7002, ST has the 7002 is not compatible for the Fibre network in my estate.
If the such a thing? I thought Dual band or not is just a feature of the router. Is there something about the 7002 that is inherently different from the 7000?
thisisnotme1212
Yes, go to http://192.168.1.254/singtel where the
userid: admin
password: H3ll0t3ch
There go to Device Status, there is what you seek....
how do we change the username/password?
wouldn't want anyone to log in to the network and change any settings.
ok..found...under access control.
why is the address /singtel needed? is it some collaboration thing between aztech and singtel?
and what is the password for other users? support, Administrator, guest?
was the username/password given to u by singtel or is it a aztech default?
thisisnotme1212
how do i configure another wireless router to act as a repeater for the main router? anyone has any idea?
Antvale
Aztech default.
Antvale
1) Login to the gui of the router to be configured as a repeater.
2) Disable 'DHCP', Save & Reboot.
3) Connects LAN cable to ethernet port of router to the ethernet port of the main rg.
imSUNEAIK
hi, recently I have signed up for a 500mbps plan is currently using dual band dsl 7002 grv. For the past few months it has been okay, however recently when I was not able to get internet. Sometimes when I turn on the router , I would get red led on the internet indicator while my broadband is still showing green. Any help would be appreciated. thanks !
jameshong
I thought 500M plan should come with 7003 ac router...how come your is 7002?
