Aztech DSL7002GRV-(s)
ahh_boi
Hi, I'm noob at this IT thinggy.
I see my 7002 router behind got USB slot, does that mean I can plug in my ext harddisk into it and all my pcs and access to it?
Thanks!
Francis85
Hi,
Outsource or internal staff ?
Regards
Anyone facing any problems with 7002 router? If so, feel free to feedback.
Just to clarify that I am a Singtel technician. Just hoping to help out some HWZ folks. This is entirely my own capacity and has nothing to do with Singtel. It just happens that I know the folks in charge of router dept so I could try to replicate the issues in test lab and highlight to them.
I am also using 7002 at home. I believe it will benefit all of us.
cheesepies
hi all,
can i check if i can throw away this default router from singtel and plug an Asus N66U on it ?
do i need to change any config / settings or just Plug and Play ?
This default router looks so ugly and the wifi signal is damn weak for my sister's 2 storey hse.
Thanks in advance.
maxsony
hi all,
Thanks in advance.
Don throw away this router away, you may need it if your fibre encounter problem and singtel tech will only assist in resolving if you switch back to this router. so just keep it just in case.
As for the 2 storey house or HDB, better get AC66/AC68 instead, yes even though it is a bit more exp than N66.. it will worth every penny spent. AC will allow you to get much better wifi network coverage as compared to N router. and once AC become mainstream and the standard.. N router will start to phrase out, just like the G wifi router now.
cheesepies
woo, thanks for your info !
lucky i never tell my sis to dump it immediately :s13::s13::s13:
Henry Ng
Aztech 7002 is same performance as your ASUS N66U. Recently ASUS AC router has a lot of issues and ASUS not working on weekend. Even you get ASUS AC router you will not enjoy full speed. When ST upgrade to Aztech 7003 which is AC router they will change your router based on 1 to 1 exchange. They will need the old router back. Suggest u get contractor to do proper wiring. With wired conntection I get full speed even to Hong Kong and china sites. Speedtest is full speed to HK and China.
funnieguy
FTP
super frustrated. i tried port forwarding port 2000 on Aztech DSL7002GRV-(s) for one of my ftp server. it doesn't work. called singtel. singtel ask me call aztech. aztech never picks up. has anybody been successful? is there any required step other than Firewall Configuration -> Port Forwarding? interface set to eth0.
zbeyuz
Anyone know how to change from Singtel DNS to Google DNS ?
I can access to 192.168.1.254/singtel but I have no idea where can change the DNS.
I looked into WAN page, but there I was not able to edit the setting, even I tried with many browsers rather than Chrome, Firefox.
Any idea ?
mOomOo
tidalstorm
Got 200mbps singnet yesterday. My wireless speed only 40mbps, wired is 200mbps. Modem is aztech 7000 not 7002. May I know is the 7000 so crappy as my wireless is only 40mbps. Any settings I can tweak? I used my note 3 to test.Thanks.
renfred89
note 3 should be able to achieve around 70mbps max...
everything depends on your wireless settings, wireless environment and congestion.
tidalstorm
Only realised my model is the 7000 and not 7002. Seems like it is the single band of the aztech 7000. But then single band so cui meh?
renfred89
you need to define cui.
singtel usually will tell you beforehand the maximum reality throughput is how much, that is 70mbps (300mbps theoretical speed).
Therefore to achieve the full speed, you need to check your wireless environment and whether your wireless client is capable of supporting the theoretical speed of 300mbps.
usually mobile devices do not support MIMO. note 3 is one of these (1x1 only).
(300/4 = 75mbps, about 30mbps in reality)
currently from what i understand, iPad air and iPad mini retina display are MIMO devices supporting ac also.
Henry Ng
If you sign during major fair then is 7002 and if you sign during normal day then must sign 300Mbps to get Dual band router. You can call 1688 to blame them for not telling you properly and request them to change to Dual band router and upgrade to 300M plan. Can be done. Of course pay a bit more every month as it is 300M plan now.
VodkaPear
Hi,
I need some help, am using Singnet fibre now.
Current setup is:
My ONT and Aztech 7002 are located at the living room. Reason being is I need a home telephone to be station down there.
From there, there is a very long cable connect to my mio tv box which is in my room.
My devices such as iPhone, iPad, MBP, Apple TV are connecting to Aztech 7002 by wireless.
But now I need to include a Apple Airport Express in my room as I need the airplay function to connect my devices to the speaker wirelessly.
As I only have a super long cat5 cable, therefore I can only use the cable to connect to the Airport Express and from there another short cable to connect to mio tv.
My others devices can connect to the Airport Express by wireless.
Am I able to do that?
Does Airport express support IPTV?
Cuz I afraid that my mio tv will not work if I do not connect directly to Aztech 7002 but instead connect it to the airport express.
If it is possible, what settings to i need to setup?
Thanks for help in adv!
zypheus
Hello bros, I am now using Aztech DSL7002GRV but my PC is located in my room which is about 30m away from the router. Hence, I need to depend on powerline for connection but the connection is crap. I am subscribing a 300mb/s plan but only get 15mb/s most of the time. Here are my qns:
1. Do you tink I shd buy the ASUS RT-AC68U? which I am afraid give me crap performance again its v ex router.
2. What is the diff between AC router and non AC?
3. How I know whether my PC wireless can Support AC router?
4. Lastly, if any1 here has RT-AC68U can let me try LOL, I pay u rental fee plus give u my NRIC? LOL
Thanks broz !!!
