Aztech DSL7002GRV-(s)
viberzdae
Tested my singtel wifi connection at home with 1 z5 android 6.0 , 1 s6 edge android 6.0, 1 s6 android 6.0 all can connect to wifi but no internet.
But these 3 phones can access all other wifi anywhere else. Only my home cannot.
But my wifi at home isnt faulty either. It can work on my windows laptop, iphone 6s and my android 5.1 tablet.
Tot is router problem so bought an asus router instead and the same error occur.
So i wonder what fault could it be?
Error msg on my android 6.0 phone is cannot detect broadband signal due to physical connectivity error.
But wifi is perfectly working on all other devices.
Why whywhy? Any solution?
If u all say it is device... But my phones can access all other wifi signal anywhere too.
Haiz
ChronoCross
Anyone tried flashing firmware with OpenWRT? I'm worried that the mioVoice cannot work after that.
ZrE0_Cha0s
Haiz
This could be poor vlan tagging, since u bought a Asus router have u checked it b4?
CarbonoAtom
Haiz
Hey I have the same problem with my s6.. all other devices work excpet for my S6 which was recently updated to mm..... I think its a Singtel Problem....
Strikk
Just upgraded to 500mbps, can this router support 500mbps download speed? I did speedtest and its only about 350mbps download.
renfred89
of cos can. last time 7002 was also given out to 500mbps subscribers what.
you did a speed test using lan or wireless?
Strikk
Using Lan. So I should be getting download speed in the range of 500mbps using speedtest?
renfred89
technically you should. but have u determined if your pc/laptop is capable of supporting 500mbps? i mean, are the settings correct? driver updated? on power saving mode etc?
Maximus_XXVIII
Aztech 7002 confirm can be used on 500mbps plan, in fact the router can support speeds higher than 500mbps.
I was on ST 500mbps previously and they provided me with the Aztech 7002, speed tests were in the 500mbps (wired) range as expected.
I even tested the Aztech 7002 after upgrading to 1gbps and I could hit 800mbps with it.
Strikk
Im using PC hmm. Settings ?
Could it be due to lan wire ? Im using a blue lan wire and a yellow one from ONT to router.
ZrE0_Cha0s
Doesnt say on the blue cable. The yellow one from ONT to modem is cat 6.
may i ask whats ur pc mobo? blue cable most of the time is cat 5e though which can support up to 1gbps though. (under short distance)
