ZrE0_Cha0s
- Jun 21, 2011
Thanks for the help. Appreciate it. My mobo is Asus M5a97 Evo R2.0.
may i ask have u change any settings to ur pc or router b4?
Nope, I didnt change any setting at all. Not familar with network terms and stuff, assemble computer still okay but network stuff abit out of my depth.
I was on 200mbps until during IT show weekend when I upgraded to 500mbps online. My service went down on 0000 5th May for a minute and I went to check on speedtest and it shows 350mbps download, 500+upload.
Did the on off router and ont today and my speed is still the same, 350mbps download on speedtest.
Any ideas? Change cable? Upgrade software ?
When you say reset you mean go to the homepage and find the reset option? or on off the router?
Still 350 to 400 from speedtest.
Probably ill change the cable. Should I change to Cat 6a or cat 7?
I just want the speed I paid for lols. 50 bucks can get good quality one?
The fibre point is inside my room. So no problem. Direct connection less than 10metre.
Thanks bro, what cat best ?
