- Jun 20, 2007
Impossible to do so... lol...
argh.... sucks man.... guess i'll have to wait till contract over.
Since you're not using Digital Phone and MioTV, I don't see why you cannot use other brand Router.anyone tried calling singtel to disable vlan on their side?
i'm not using telephone and mio tv.
can i do that so i can get a TP link Archer C7 to replace the crappy 7002.
does anyone know how to remove DHCP Server assigned devices?
Hi,
I would like to set up QoS to limit the bandwidth of 1 single device. Can any kind soul advise how do I go about doing that on the DSL7002GRV?
Thanks!
QoS does not limit the bandwidth of 1 device only. that is known as a bandwidth limiter which is not available on 7002.
Hi,
Thanks!
What is the admin password for DSL7002GRV?
Thanks! This helps...Password: H3ll0t3ch
anyone knows how to set this modem to Direct IP mode? Is it using Bridging? I tried connecting it to my switch using bridge mode but cant seem to get IP address from the switch
what is direct ip? you mean static IP is it?
what switch is that? managed or unmanaged?
i am thinking of using this aztech router to act as a dumb switch, when i set the router to bridge mode, there was no ip issued to the router
cisco switch unmanaged
does this router perform well with 1Gbps plan?
If you have recently upgraded to 1gbps, th3n you will be given the new 7009 lor..
