monikernemo
- Oct 23, 2014
hahaha use the intel fan la
Problem is Haswell E CPUs no stock heatsink fans
Sent from microwave oven using GAGT
Installed an air cooler TnT bought this deepcool neptwin tower heatsink from this guy for 40. Feels really light and cheap :Oohh you got the haswell E ah. haha
borrow lor. usually people will test first. to be safe
ok la the bios. haha used to it.
but i oc once, i never go in again. haha
Wah you jin satki set one time stable Liao Haha
Asus one last time keep tweaking, but quite accessible imo la.
either that or maybe it's basically the same thing just that I haven't gotten used to it
no la. a few tries.
i meant once i get a good stable OC. i am done. haha
4.5ghz @ 1.235v sounds ok to me. haha
hi moniker, wondering, where u bought your x99a sli krait from?
:OOO
Too generic Liao the name
Actually see how la but I purchased the flexi tubings Liao hmm think first loh.
Arghhh thanks Haha. I think may go with swiftech.
Dunch poison me hahaha
I going soft tube buy the tubes Liao paiseh haha
Hard tube for first timer looks daunting
For us we found a cheap way, like 1/5-1/10 the normal price
Used to have a neptwin. They're heavy... And cheap feeling? I don't think soInstalled an air cooler TnT bought this deepcool neptwin tower heatsink from this guy for 40. Feels really light and cheap :O
My first time ever installing after market air cooler. H100i alot easier to install I swear...
Applied alot of pressure when installing CPU but Heng never brick the CPU or what
Managed to boot !! No ram erors or what not so quite Heng. Abit kumgong forget to install pcie WiFi card...
As for bios, abit luan but guess will navigate thru bah. Otherwise will try and update more soon!
DMC? Never a fan of that LOLDevil May Cry
My mate did acrylic tubing on first goFor us we found a cheap way, like 1/5-1/10 the normal price
You can go with silverstone PWM splitter if can find, they're smaller and you don't need to bend your wires as much as the swiftech ...
Used to have a neptwin. They're heavy... And cheap feeling? I don't think so![]()
Was considering that too looks more elegant hmm but that thing is not to see daylight anyways so... Whats the 'cheap' way? I bought tubings already so might as well.
It feels really light imo compared to DRP3?
Paint on a rubber is a bad idea. Did it once and the moment something touched it bye bye goes the paint.![]()
On a bad camera, sure doesn't look too bad...
But up close looks quite uneven.
Need to focus on the 'antennas' abit more.
The paint comes off really easily if you flex the rubber alot. The rubber coating coming off this one because i bent it quite vigorously earlier. Might be redoing as well...
Prolly the structure of the rubber breaks up and stretches, becoming looser and less adhesive to the surface when you bend it.
Deepcool heatsinks are already comparably the heaviest on the market ... And DRP3 is just ENORMOUS.
Read alot about rubber and paint. The issue is that while most paint coatings are rigid, rubber is flexible so therefore the paint wears easily. I'm using plastidip Btw, and do find that it is easy for the paint to come off the rubber too despite its rather elastic nature.
Well thanks for the info on heatsinks Haha as I've said this is my second heatsink. Drp3 being the first.
If you insistRubber paint + rubber = double disaster
Well to be fair it's not supposed to be heavy. The Assassin is the true definition of heavy ...
In fact if light = cheap, then I suppose ALL CM heatsinks feels cheap then![]()
