[CASE] Phanteks Enthoo EVOLV ATX
dawntime
molex or 3 pin will do!
A shop at level 5 or 6 in SLS (an auntie runs it) did it for me couple of months back. Can't recall which in exact.
Side question... You bought the evolv ITX already? I wanna hoot but SLS no stock from what I heard...
poooooo
Good morning dawntime kor kor :)
@Corbell
Suspended
Hi, I'm looking at the Evolv itx case. If I want to install LED light strips in the case without those fancy lighting. Just single color light only. What do I need to buy to install the light?
Sorry if this question is too newbie. First time installing LED light inside PC casing.
The LED strips currently are only supported on Enthoo Luxe, Mini XL, Evolv ATX TG, and P400/P400S.
Unfortunately the Evolv ITX is not support.
However, there are single color LEDs in the market, like the Xigmatek Xi-Ray which we have stocks too.
http://www.xigmatek.com/product.php?productid=221
@Corbell
Suspended
Hi bro, for Evolv ITX Chassis, new shipment just came this monday.
All in SLS @ Cybermind, Fuwell, PC Themes, Media mart, Scorpia, Make Fine now.
Black, Red and White color. Stocks not a lot. :o
http://www.phanteks.com/Enthoo-Evolv-ITX.html
Nights
Not yet. I'm comparing evolv itx and the define nano S. I don't know this case so hot till OOS. I prefer white but nano S has no white color.
Thanks for the recommendation. Will check it out :)
dawntime
yaaaaasss me too! white! common shops OOS...
dawntime
Hello Kor Kor =:p
Hey thanks. Heard from a shop saying this case OOS liao from most other shops as well... Next shipment arriving delayed to mid july? :(
Later I hooting liao....
ExArchz
Anyone used the LED strip on their phanteks evolv atx TP? can share pics?
@Corbell
Suspended
Received this picture just now. A colleague's friend replaced his old case to an ENTHOO SERIES Evolv ATX Tempered Glass. :D
His old MSI mobo, vga card and GSkill still remain.
HungryPillow
When will Enthoo Tempered Glass be available on Lazada again? I was gonna wait and buy during the weekend discount but it's out of stock already lol
@Corbell
Suspended
Next shipment should arrive end of July. But as of now, you can buy from SLS shops. =:p
m4gg0t
Just got my case built, however the RGB LEDs on the bottom of the front pannel and the power button do not work?
royfrosty
There is a 12v power connector that needs to run it iirc for the LEDs. Its at the fan hub there with a 12v to SATA.
m4gg0t
I have the fan hub connected to a SATA cable on the fan hub. Are you talking about the other SATA cable that comes from the top?
jedi5diah
top - one 12v for power hdd leds
attached to fan hub - one 12v for optional 2 led strips (not sure if able to use non phanteks strips)
small complaint: both 12v sata cables are so short esp the fan hub one...making impossible to hide them inside the psu area for "cable management"
m4gg0t
Haha i know the feeling, spent 2hrs trying to cable manage. Finally got it good enough. I didn't know you had to connect both 12v SATA cables.
